track car radiator ducting project - many pics
Old Jul 27, 2004 | 10:07 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
well, i did a hack job with aluminum sheets on the track car and though it was time to do a bit better job on the radiator ducting. I had a few weeks down time between track events and decieded to take the nose apart and try some stuff, basically i made a dedicated radiator duct that will replace the stock underpanel, eventually under that will be a full flat underpanel for, but here are the first run of pics on the rad ducting project:
back side of cardboard mockup getting fiberglassed
i just used cardboard to make the ducting mold and fiberglassed right ont he cardboard, making the cardboard become the 'skeleton' of the duct
a shot of it after i got the first layers of fiberglass on it
another shot fully glassed, it was a messy project :-)
i sanded it down but i wasnt too good about making it perfectly smooth
after a first coat of black spray paint
following a suggestion from the master (Noah at speedlabs) I used rubber flaps as the seal to the awkward power-stearing pipes that run in front of the radiator
I used velcro to keep the 'free' side of the rubber flaps in place
a test fit on the car, looking good so far :-)
Old Jul 27, 2004 | 10:25 PM
BigIslandSevens's Avatar
Nice work Damian.
That actuially looks alot like the one I made for a customer. Stock 93 R1 bumper. Greddy FMIC and KOYO rad. I'll send you some pics of it.
Mine was fabbed out of 18 gauge steel. I am thinking of glassing it. Although I am confused as to how I would connect the uprights. Maybe you could give me an idea when you see mine. If you want to!
Now all you have to do is the air intake ducting!!!
On a side note. A few of the people I showed the scoop to during fabb, just laughed and made fun of the akward looks of my contraption. Well when it lowered his water temps by 25-30 degrees he shut up quickly. Seriously the temps were at 240 sitting in the shop after warm up. Dropped to 180 cruising and only have seen 195 with alot of "spirited" driving. Function over form anyday for me!!
Also what are you going to do for the top side? To keep the air from pushing out the top. I made a full plate for the gap between the Rad. and IC. But I am going to redue it for the whole bumper support area. ( cleaner look)
Old Jul 27, 2004 | 10:44 PM
Fatman0203's Avatar
Damian care to do a write up on how to remove the front bumber =P? Or you used the shop manual?
Old Jul 27, 2004 | 10:55 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
thanks BigIslandSevens :-)
well, i attached the sides by using a strip of fiber glass that i layed down on a scrap piece of cardboard and 'painted' the resin on, then i layed it on the moild in the corners and used a foam brush (dipped in resin) to form the fiberglass strip into the courner, i did that a few times on each vertical 'fin' corner and that was that, pretty simple.
well, its already build into this mold, i just dont have the final side wall up, it will make more sence in later pics
Old Jul 27, 2004 | 10:57 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
hmm, well this is not a stock nose, its a mazdaspeed gtc and does not have stock rebar, popup light, et..... so for this car its real easy, just a few bolts and it comes off :-) i have never taken off the stock nose on my other car, so cant help ya there, sorry ;-)
Old Jul 27, 2004 | 11:04 PM
Fatman0203's Avatar
Doh!
Actually Ive been thinking of doing something similair to this for a long time. As a cold air box. I get massive amounts of boxes (cardboard) at my job, just the space time would be the only thing. Cool stuff damain, keep us updated on those temps.
Old Jul 27, 2004 | 11:15 PM
Slam Pig
cool...it looks sweeter then mine
mine is made from sheet metal..i might try this approach
Old Jul 27, 2004 | 11:16 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Originally Posted by obviousboy
sweet...it looks sweeter then mine
:-) ohh well, i try :-)
Old Jul 27, 2004 | 11:18 PM
Slam Pig
are you running a fmic behind this??
Old Jul 27, 2004 | 11:25 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
hmm, i think you ment 'in front of' this for a fmic, a fmic can not go 'behind' this..... but in either case, no, i have a smic.
Old Jul 27, 2004 | 11:29 PM
Slam Pig
ahh i actually ment to say in this...
Old Jul 27, 2004 | 11:35 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
ahh, i see, ..nope, i have a real big smic, i am partial to smic for road racing cars, better cooland temps.
Old Jul 28, 2004 | 01:24 AM
turbojeff's Avatar
Do it right, do it once
Damian,
Excellent job. I usually look at these threads with an eye towards what is wrong with the mod because so many mods screw up the car. I like the belly pan, I hope it is strong enough to hold up to high speed.
I LOVE the rubber around the PS line and the super duty velcro used to hold it down. That stuff kicks ***!
Great job!
Old Jul 28, 2004 | 01:44 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
thanks jeff :-)
it definetly should hold up, i used a few layers of fiber glass and the cardboard had a corrigated (sp?) center so it added a LOT of strength to it.
more pics to come as i get it further along...
Old Jul 28, 2004 | 01:52 AM
Exlex's Avatar
Nice! Looking forward to more pics
Old Jul 28, 2004 | 02:14 AM
EFS.O's Avatar
Hey Damian,great idea man.Thats another thing added to my "things to do list".Btw,now that you have the bumper off,switch to "full ghetto mode",and for your oil coolers do something like this:
Attached Thumbnails track car radiator ducting project - many pics-img_3625.jpg
Old Jul 28, 2004 | 10:16 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
they kinda are like that already, i getto-fabbed ducting with aluminum, sealed with metal plumbing tape, and have the wire mesh stuff, but it hooks to the nose, not the duct ;-)
Old Jul 28, 2004 | 10:31 AM
DamonB's Avatar
That is a TERRIBLE idea. You've just covered up most of the open duct so that you're no longer capable of getting much air actually through that mesh and into the cooler. I bet your void area is maybe 50%.
Old Jul 28, 2004 | 10:40 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
yeah, use bigger mesh LOL
Old Jul 28, 2004 | 01:47 PM
EFS.O's Avatar
Well,maybe you are right,maybe you are wrong.I used an air compressor to test it,and it seems to work fine.No more worries about damaged fins from small rocks and huge bugs.I also used an audi tt vent for the fender(the stock vent sucks),and it works fine....
P.S the mesh is fairly large,its just the flash that makes it look small...:-)
Attached Thumbnails track car radiator ducting project - many pics-img_4405.jpg
Old Jul 28, 2004 | 02:05 PM
Kento's Avatar
2/4 wheel cornering fiend
I'd have to agree. The earlier Suzuki GSX-R sportbikes used to have a similar thick mesh inside their ram-air intake ducts (probably more for styling than anything); an aerodynamicist friend theorized that they were a major obstruction to airflow. We conducted a test by doing several top speed runs for a baseline, then pulled them out and repeated. Without the thick mesh, the GSX-R was nearly 3 mph faster on top, which is a major power increase considering the aerodynamic drag at those speeds.
Old Jul 28, 2004 | 02:22 PM
rx7tt95's Avatar
Photo Diety
One should always use a mesh with a high void ratio. Usually this means an octagonal or square pattern. The larger the voids, the better. Using that style of grill mesh does indeed cut the airflow to more than half of the original. I'd get it off of there asap. If Greece is as hot as it is here in SW Florida, you're just asking for trouble
Kent, any chance you guys are going to get a new MV1000 for a full road test vs. some of the other liter bikes? I liked Alan's writeup but he's an MV owner and therefore biased.
Old Jul 28, 2004 | 03:13 PM
lopedl's Avatar
Forever Modified
Cool!
Old Jul 28, 2004 | 03:21 PM
pomanferrari's Avatar
On the other hand, for convective cooling, you want turbulent air flow. That mesh sure looked like it will cause a hell of a turbulent air flow.
Old Jul 28, 2004 | 03:35 PM
DamonB's Avatar
I would point out that if you're going to have AIR cooling you're going to need...AIR.
Convective cooling is for people who are trying to impress themselves with vocabulary.
