Dang flywheel nut won't come off
Old Jun 11, 2004 | 04:01 PM
ShadowX's Avatar
I've already got the tranny out, along with the clutch and pressure plate, and now I'm stuck on the flywheel nut. I'm using a breakbar and a flywheel break, and all that's happening is the engine is torquing in the mounts. I didn't want to keep trying, see the engine move like that was a little unsettling. Should I just keep trying or did I forget something along the way?
Old Jun 11, 2004 | 04:05 PM
SonicRaT's Avatar
Super Raterhater
Get an impact, it makes life 50x easier. That or get someone to try to brace the engine in place as you torque on it.
Old Jun 11, 2004 | 04:15 PM
Steel's Avatar
I'm your huckleberry..
YEah, those things are originally torqued to aobut 300 foot pounds, add 17 years of not moving = impact driver needed.
Old Jun 11, 2004 | 04:29 PM
ShadowX's Avatar
Well that's comforting, I was starting to think something was seriously wrong.
Old Jun 11, 2004 | 04:39 PM
ZoomZoomH's Avatar
a nice AIR impact wrench outta loosen that bitch up.
Old Jun 11, 2004 | 04:44 PM
boosted1205's Avatar
You need a strong impact. I had an FD flywheel nut *STUCK* like you wouldn't believe. If an impact does not work, you need to jam the flywheel. Below the clutch slave, there is a aluminum plate held on by a 10mm bolt. Remove that and jam a pipe in there such as a floor jack pipe( perfect size..what I used). You might want to unbolt the clutch slave just in case. The flywheel will lock and then use a breaker bar.
Old Jun 11, 2004 | 05:08 PM
PHATFC3S's Avatar
kichiku beihei
i couldnt even get mine off with an impact wrench.. i ended up having to use a hammer and a chisel to get it off. and then had to buy a new nut because we destroyed that one.
Old Jun 11, 2004 | 05:40 PM
Mr. Gadget's Avatar
Older than Dirt
the mazdatrix flywheel stopper is one of the best 20.00 i have ever spent. both the fornt bolt and the flywheel nut are child's play once the engine is locked down
Old Jun 11, 2004 | 05:46 PM
glorthu's Avatar
I tried a breaker bar, hammering, impact wrench, lots of lube, sweet talk, nothing would get that nut off! ... I'm talking about the flywheel nut, sicko!
Anyway, what finally worked for me was heating it for a little while with a propane torch. Then it came off nice-n-easy.
Old Jun 11, 2004 | 06:00 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
torch + imact wrench + hitting it for about 5 minutes = got it off.
nothing else would. NOTHING.
it was UBER strong.
Old Jun 11, 2004 | 06:05 PM
drago86's Avatar
Put the car up on ramps, brace the flywheel somehow, put a breaker bar on the nut, facing down, slip a pipe over the breaker bar and let it slip all the way down to the ground, should be bout 2+ feet long, kick breaker bar as hard as you can from the side of the car, may need a friend to sit back to back to brace you, flywheel nut off.
Old Jun 11, 2004 | 07:06 PM
use a hammer and a chisel it works better than anything in the world trust me i used it 3 times works great
Old Jun 11, 2004 | 07:28 PM
Audiofight's Avatar
Impact all the way
I broke teeth off my flywheel ring gear when trying to use a brace and a 14' "persuader"
The impact zipped it off no problem. We had our air compressor pushing 125 psi, which most decent compressors should be able to handle.
Good luck
Old Jun 12, 2004 | 12:32 AM
lacycw's Avatar
Definately try heating it up with a torch. It probably has loctite on it and by heating up the nut, it will expand making it easier to take off.
- Coop
Old Jun 13, 2004 | 08:43 AM
croffeyc's Avatar
RLRR LRLL
The flywheel stopper works wonders.
Breaker bar with a long piece of metal tubing for additional leverage and coercing it with a sledge knocked it loose for me.
Old Jun 13, 2004 | 10:32 AM
dubrc's Avatar
yeah a nice big piece of pipe on the old breaker bar works, but I snapped a 1/2" bar at about 600 lbs of force. I think it's only the front bolt that has the locktite on it, but anyways a impact gun is the best. If you got a compressor, you could probabily rent a gun or borrow one. My roomates a truck mechanic and they've got a 1" drive pushing something like 1200 lbs of torque.
--Paul
Old Jun 13, 2004 | 10:41 AM
$100T2's Avatar
On the prowl for an FB
Or, you could go to the Mazda dealer, and borrow their torque multiplier that is specifically designed for the job... Just give 'em your drivers licence and slip the guy $20 to let you borrow it for an hour.
Old Jun 13, 2004 | 12:20 PM
Terrh's Avatar
the mazda dealer here wouldn't have anything to do with me in regards to loaning a tool. LALLO MAZDA in BRANTFORD sucks.
they'd sell me one for $389 though.
whinin
Mar 30, 2019 07:53 PM
risingsunroof82
Sep 9, 2015 08:06 PM
Enzo1944
Sep 6, 2015 08:57 AM
