Custom Oil Cooler line partlist
Old Feb 11, 2004 | 10:45 AM
25BP's Avatar
I want to post the actual part list needed for making custom oil cooler lines. There are many other options on how to do this such as local fitting shops or buying the stock replacement lines from various suppliers. The threads in the past have been a great source of info, but I didn't find the exact info needed when placing orders. Here is what I assume is needed, with prices and part numbers. If anyone knows of more cost effective suppliers or if this is incorrect please post your thoughts.
Using the stock oil cooler to simply replace the lines, no special applications. AN fittings and lines are -10 and I sourced Aeroquip from Pegasus and adaptors and washers from Mazdatrix.
Here is what is needed from Mazdatrix:
www.mazdatrix.com
(3) -10 >16mm THD adaptors $9.50 per fitting =$28.50 PN#11901
(1) -10 >18mm THD adaptor $9.50 per fitting =$9.50
PN#11902
(3) Sealing washers $1.25 per fitting=$3.75
PN#41-6000-9956
(1) Sealing washers $1.25 per fitting=$1.25
Mazdatrix Total: $43.00
Here is what is needed form Pegasus:
www.pegasusautoracing.com
(1) 45 degree -10 fittings $20.99 per fitting =$20.99 PN# 3271-10-45
(3) 90 degree -10 fitting $21.99 per fitting =$65.97 PN# 3271-10-90
(8 Feet+) -10 hose $6.49 per foot = $51.92
PN#3270-10
Pegasus Total: $138.88
Total parts only not including shipping: $181.88
Here is a narrative of what is happening:
From the rear housing to the cooler:
Maxdatrix sealing washer PN# 41-6000-9956
Mazdatrix adaptor fitting PN#11902
Aeroquip 90 degree fitting PN#3271-10-90
Aeroquip -10 hose PN#3270-10
Mazdatrix adaptor fitting PN#11901
Mazdatrix sealing washer PN#41-6000-9956
From the front cover to the cooler:
Mazdatrix sealing washer PN#41-8000-9956
Aeroquip 45 degree fitting PN#3271-10-45
Mazdatrix sealing waher PN#41-6000-9956
That apears to be it. I stated 8 feet of -10 hose and that may be a little more then actually needed. It leaves a little extra if a mistake is made on cutting etc.
Again, I know this is not the most cost effective method out there but demonstrates what is needed for building your own AN fitted oil cooler lines.
I am not repsonsible for errors in pricing or part numbers supplied. Please confirm before ordering.
Again, if these PN's are incorrect please list corrections.
Hope it helps.
Old Feb 11, 2004 | 10:47 AM
Aaron Cake's Avatar
Engine, Not Motor
Awesome! Archive material!
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
