flywheel question
Old Feb 3, 2004 | 12:14 AM
rx78788's Avatar
flywheel question
i'm trying the flywheel off, but i don't have a big enough socket for it. does any one know what size it is so i can go [ick on up. thanks
Old Feb 3, 2004 | 12:18 AM
PHATFC3S's Avatar
kichiku beihei
i think its 21/8 or 23/8 i cant remember
Old Feb 3, 2004 | 12:23 AM
FC3S.USD's Avatar
Where is my Life ?
I ran into that problem a little while ago it was hard for me to find a place here in ottawa that carried the socket, I ended up having to get it from snap on.
Its a 54mm socket or its equivalent 2 1/8 '' they both work perfect.
hope that helps
Old Feb 3, 2004 | 12:27 AM
rx78788's Avatar
yup that's perfect thanks
Old Feb 3, 2004 | 12:31 AM
Wyznewski's Avatar
Happy Noodle Being
This is the tool we used on mine. 2 1/8" socket on a 3/4" rachet and 4 ft of cheater bar.
Old Feb 3, 2004 | 12:34 AM
Wyznewski's Avatar
Happy Noodle Being
And this is the breaker bar we broke before we got out the big ratchet. Moral of the story: use Craftsman tools.
Old Feb 3, 2004 | 01:18 AM
Nismo Convert86's Avatar
400WHP or bust
a coal chisel and a hammer works well too, but a socket is the ideal tool, I was in Sears one day and they had a socket for 23.99 CDN, use it and return it
Old Feb 3, 2004 | 01:29 AM
rx78788's Avatar
that would work, what is a coal chisel?
Old Feb 3, 2004 | 03:47 AM
Spraintz's Avatar
Edmond Dantes
That big socket I got from sears and used an impact wrench to get mine off. came off pretty easy.
if you don't have any air tools, the ghetto-cheesy walmart electric "impact wrench" will work also
Old Feb 3, 2004 | 06:52 AM
SideWindeRx7's Avatar
air tools make everything easier
Old Feb 3, 2004 | 08:17 AM
Hot_Dog's Avatar
Re: flywheel question
Go to your local Sears store (or sears.com) and buy a 3/4" drive 2-1/8" socket -- it'll fit the nut and it's relatively cheap at around $20. If you have access to an impact wrench (1/2" but 3/4" is preferred), than you spin that nut right off. Otherwise, you'll need to get your hands on a 3/4" T-handle or breaker bar, and you'll probably also need a cheater bar, to break that nut loose.
Hot_Dog
90 RX7 GXL
02 Acura RSX-S
_Tones_
May 25, 2021 05:37 AM
sinclair7seven
11
Sep 11, 2015 10:15 AM
Enzo1944
Sep 6, 2015 08:57 AM
Nosferatu
Sep 5, 2015 02:13 PM
