who ran 11.1 on twins????
Old Jun 24, 2002 | 07:44 PM
93redFD's Avatar
Who ran 11.1 on twins???? I really would like to no the what there setup was.. I no a 95% of that time was the driver but I really would like to now there setup..
Old Jun 24, 2002 | 08:39 PM
13BAce's Avatar
On a long vacation
AnthonyNYC
http://www.rx7s.com/tandrracing/team/anthony/mods.HTM
Old Jun 24, 2002 | 09:20 PM
AnthonyNYC's Avatar
Stay tuned...
That was me, nothing special.
The regular mods will get you into the mid-high 11s, throw some gears and raise the boost a little and low 11's is pretty easy with good driving.
I just copied Brooks old car and added gears and some more fuel for higher boost.
13Bace, my neighbor , listed the mod page.
Anthony
Old Jun 25, 2002 | 11:29 AM
13BAce's Avatar
On a long vacation
Anthony
Did you move in yet? I don't hear much noise.
Old Jun 26, 2002 | 08:51 AM
RecKleSs's Avatar
Adrenaline
I'm sure Anthony could have pulled a better time if he would reduce some of the weight on his FD. Anthony has sleeping bags, books, spare tire in the rear, and a bunch of other **** that he leaves in there while he races. Maybe one day he will remove some things out of there.
Old Jun 26, 2002 | 12:12 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
Wouldnt all that stuff just add to the rear traction of the car?
Old Jun 26, 2002 | 02:41 PM
ErnieT's Avatar
Living life 9 seconds at a time
Originally posted by Dont_Be_A_Rikki
I can taste the 11's so bad I just want to get there any 11's I know I can just need to learn how to drive
-Rikki
Not with the PFS PMC your not.....LOL
Old Jun 26, 2002 | 02:57 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Anthony, did you ever have ignition probs with at those boost levels??? I noticed you had bone stock ignition with no amp box or anything. If you dont mind me asking what plugs were you running and did you just run them at the track or all the time?
Thanks man,
STEPHEN
Old Jun 26, 2002 | 08:57 PM
AnthonyNYC's Avatar
Stay tuned...
Thanks man,
STEPHEN
NOPE, never had any problems whatsever. That was such a sweet setup! Man, I miss those days!! I was going to get an ignition amplifier but just never got around to it.
As for running with sleeping bags lol, that was my car cover. I did run the car with a system installed also. I am getting the car ready for this next weekend. Theres a nice event at Etown Raceway.
Anthony
Old Jun 26, 2002 | 08:59 PM
AnthonyNYC's Avatar
Stay tuned...
lol, not yet, closing is on the 30th of next month. I will get the N1 Silencer installed since my neighbors look really quiet.
I passed by your house everytime I am there but never see you outside!
Anthony
Old Jun 27, 2002 | 02:11 AM
93redFD's Avatar
anthony,, what kinda tires??? slicks?? drag radials???
Old Jun 27, 2002 | 09:48 AM
13BAce's Avatar
On a long vacation
What a good neighbor.
Anthony
I've been kind of busy. MY car has been running pretty well. So there's not much to do outside besides yardwork.
Old Jun 27, 2002 | 10:21 AM
SPOautos's Avatar
Where you running a pretty cold plug? I know alot of guys run B10EGV's
Just curious what kind of plug you were running.
Thanks man,
STEPHEN
Old Jun 27, 2002 | 09:37 PM
AnthonyNYC's Avatar
Stay tuned...
Thanks man,
STEPHEN
I was using these Greddy plugs that Rampage Racing recommended.
Anthony
Old Jun 27, 2002 | 09:38 PM
AnthonyNYC's Avatar
Stay tuned...
Slicks!
There is NO WAY I would even come close to taht time with drag radials. I tried and could not. I would only manage high 11s.
I was running street slicks or so they are called.
Mickey Thompson Street ET'S
Anthony
Old Jun 29, 2002 | 01:41 PM
efiniracing's Avatar
Anthony, i pretty much have the same setup as you do but I can't get my 60'ft time below 1.9. How do you do your burnouts? (1st gear, 2nd gear) and what rpm do you launch at? thanks in advance!
Old Jul 1, 2002 | 01:36 AM
AnthonyNYC's Avatar
Stay tuned...
I do my burnouts in 1st gear only. I run through the water box, spin em, move up, heat them up really nice, stage, start reving from 4-6k rpms, pin the pedal at 4k Rpms and then pop the clutch.
Thats it...
I usually launch at 5k-6k.
What tires are you using?
Anthony
Old Jul 2, 2002 | 11:40 PM
I'm using Toyo Proxe drag radials. They seem pretty sticky, I launch at 6-7k too but I think part of the problem is that I have factory shocks and the car doesn't squat.
Do you do a true burnout where you step on the brakes? or just rev high and let the clutch go ?
Old Jul 3, 2002 | 02:04 AM
93redFD's Avatar
i kinda need some advice on launching a car with slicks because I really dont wont to look like a dumb *** that cant do a burn out with slicks.. I tried holding the brake with street tires and the *** end moves to the right to much!!(it was just for fun though,I dont do that at the strip!!!)
Old Jul 3, 2002 | 07:44 PM
AnthonyNYC's Avatar
Stay tuned...
I have the stock factory shocks also but lowered springs. I do a true burnout where you step on the brakes and sit in one spot. I always run through the water box, this way they dont hook right away and you can heat them up really well.
Anthony
Old Jul 3, 2002 | 07:49 PM
AnthonyNYC's Avatar
Stay tuned...
Same as my other post, just spin in the water box, then move up to the dry area, then spin em!
http://www.rx7s.com/tandrracing/even...%20%20mpeg.avi
Here's a link of a burnout with slicks.
Anthony
Old Jul 4, 2002 | 01:49 AM
Anthony, do you have your abs fuse taken out? Thanks again.
Old Jul 4, 2002 | 09:45 AM
AnthonyNYC's Avatar
Stay tuned...
I never took it out. I read about that from Brooks old site but I never took it out.
Anthony
Old Jul 4, 2002 | 12:39 PM
Thnaks for all your help Anthony, I'm planning to go to the track next Friday. I can't wait, hopefully I'll hit 11's.
