Wanting to install stock wing, how do I align it?
Old May 1, 2003 | 12:59 PM
ejmack1's Avatar
Lawn Ornament
Anyone have some close up pics of there wing? Or installation tips?
Old May 1, 2003 | 01:13 PM
Rated R1's Avatar
Oji San
I've got one. PM me your e-mail and I'll send it to you.
Old May 1, 2003 | 01:15 PM
tgriesel's Avatar
I'm interested too. I was just going to tape some brown packaging paper on the rear hatch where the mounts are, line up the wing, trace it and then use the rubber gaskets to locate the holes. It shouldn't be that hard. Tom
Old May 1, 2003 | 01:45 PM
rotary-tt's Avatar
2 babies - no back seats
Try here: http://www.scuderiaciriani.com/rx7/spoiler_install.html
Print the files at 100%, cut out, align, and tape together to make a templete...
Old May 1, 2003 | 02:02 PM
AUM's Avatar
AUM
I am the Architect
Any one know where I could find a mounting template for the RZ spoiler?
Old May 1, 2003 | 02:39 PM
ejmack1's Avatar
Lawn Ornament
thank you exactly what i was looking for, I just didn't think someone had already done a write up on this!
Old May 1, 2003 | 03:46 PM
rotary-tt's Avatar
Spend some time on this site if you have not already. Most is pretty old but still relevant...
Old May 1, 2003 | 05:42 PM
ejmack1's Avatar
Lawn Ornament
lol, im not new here man, I have used that site quite frequently in my 2 years with this car. I did not ever see that on there though.
Old May 1, 2003 | 06:38 PM
RonKMiller's Avatar
Blow up or win
Eyeballing is really pretty damn good if you take your time. As good as a template.
Use a water based fine tip magic marker once you have it set just right.......
Old May 1, 2003 | 08:45 PM
rotary-tt's Avatar
Sorry, didn't know. It has been reorganized and updated in some areas but still seems to be old info (but good)...
Old Apr 10, 2004 | 10:37 AM
kevinvr6's Avatar
Gremlin Hunter
I've been reading that two of the outer holes from the stock wing is exactly the same as the holes in the 99? I'm going to be installing the 99spec wing so I figure this template will work for me? =o]
Old Apr 10, 2004 | 11:25 AM
ejmack1's Avatar
Lawn Ornament
wow, my thread resurrected 1 year later
Old Apr 10, 2004 | 11:51 AM
PVerdieck's Avatar
Here is 99 spoiler instructions and pics
http://www.negative-camber.org/crispyrx7/99wing.htm
Old Apr 10, 2004 | 11:52 AM
kevinvr6's Avatar
Gremlin Hunter
yea i've seen that, but my car has no wing to begin with so I just want to get the holes right!
Old Apr 12, 2004 | 06:36 PM
PVerdieck's Avatar
In that case, that template should work fine. Print it out and check by taping it on your hatch, and putting the 99 tail on top. Once you use that template to get a few of the common holes (between the R and the 99 tails), then you can use the other method to get the uncommon holes for the 99 tail.
dkwasherexd
May 27, 2017 04:51 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
