How do you test the AFM
Old Apr 23, 2002 | 01:40 PM
Kaizo's Avatar
Newbie
I have an 87 t2 and I get a ecu code saying that the AFM is bad. Where can I find out or can some one tell me how to test it manually if its bad?
The car idles like crap and runs bad, the ecu threw a pressure sensor code, I replaced it, and it ran a tad bit better. I have done a compression and vacume leake test and all is well. So naw I am assuming that the AFM is bad and or the TPS is bad, so plz if any one knows how to test it plz tell
Old Apr 23, 2002 | 03:58 PM
flak3r's Avatar
afm test
wellto test the AFM you need to get the service manual or look up the readings on it... idealy u test the pins on it and check the resistance from the pins..... to tell if its good or bad...
Old Apr 23, 2002 | 04:08 PM
biorotary's Avatar
are you still using the oem tid? if you are, you may have some small cracks that is allowing unmetered air in...hence the afm error...
Old Apr 23, 2002 | 04:12 PM
NZConvertible's Avatar
I'm a boost creep...
There’s a test procedure for the AFM on page 4B-60 of the FSM. Basically it’s like flak3r said, checking the resistance between the pins.
R.O.D
34
Jan 6, 2016 12:09 AM
Jmolina0163
19
Sep 25, 2015 06:06 PM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
Mps_hell
Sep 19, 2015 10:02 PM
