Rubbing on 18s
Old Dec 18, 2001 | 01:51 AM
Nameless's Avatar
Rubbing on 18s
I got some Volks on my car and it's rubbing on the front passenger fender. And man my fender is getting messed up. What do I do? Roll fenders? Cut them? Any advice would be appreciated.
If measurements are needed I'll go look at them in the daylight.
Old Dec 18, 2001 | 02:21 PM
rtryrktrx7's Avatar
I had a rubbing problem with my right fender, but I had stock wheels. I found out the strut boot on the strut was old and cracked which I was told that caused the shock to fully bottom out on big dips. I never hit the actual fender though. I just rubbed the plastic well in the fender.
I hope that helps. Sorry I couldn't give you more.
Jeremy
Old Dec 18, 2001 | 02:32 PM
dclin's Avatar
Perpetual Project
Re: Rubbing on 18s
What's your tire size?
Old Dec 18, 2001 | 02:34 PM
Nameless's Avatar
Hmm it is only happening on my front right as well...maybe thats it, I'll have to take a look....
I'm at work right now I'll check the sizes later.
Old Dec 18, 2001 | 09:05 PM
Nameless's Avatar
Using 235/40 on the front. 40 series too big?
Old Dec 18, 2001 | 09:45 PM
dclin's Avatar
Perpetual Project
A tiny bit too tall. Its the size that all teh 'experts' (read tirerack, etc) recommend though. Its ripping the fender lip out when you enter an inclined driveway going too fast, right?
Whats happening is that when your wheels are turned, going into the drive - the suspension is compressed and the tire tread contacts the fender lip, pulling it out.
So it's the diameter that's causing the problem.
Stock 225/50/16 has a theoritcal overall diameter of 24.86", were as 235/40/18 as a theoritcal overall dia of 25.4".
Alternative sizes: 225/40/18 (border line, depending on factors), 235/35/18, or 245/35/18.
keep in mind that the actual dimensions depend on the tire manufacture (same rated sizes are not the same in real life) and the width of the rim the tire is mounted on.
I'm no wheel/tire expert, but I did buy and try three differnt aftermartket 18" width/offset and tire size combinations in the past year, so this is based on experience.
Fronts:
1st set: 18X8.5 +40 235/40/18 (25.4" dia)Kumho Ecsta Supras - fender lip ripped out only under above situation
2nd set: 18X9 +42 255/35/18 (25" dia) Kumho Ecsta Supras - no more problem
current set: 18X8.5 +44 225/40/18 (25.2 dia) Pirelli P Zeros - moderate rubbing in above situation.
The 225/40/18 P Zeros are temporay until the damn 245/35/18s P Zero Directionals come back into stock, or Bridgestone releases those sizes in S03s.
Hope that helps!
Old Dec 18, 2001 | 10:03 PM
Nameless's Avatar
Thanks a bunch that helps immensely.
Old Dec 18, 2001 | 10:22 PM
dclin's Avatar
Perpetual Project
No problem - Rolling the fender lip out of the way is probably a good thing to do anyways, though some here have an aversion to modifying sheetmetal. If done correctly, no one would ever know, as that its a part of the fender thats not seen. See here for details:
http://www.overboost.com/story.asp?id=131
Tool available from Tirerack.com for 'free' (loan a tool program), but get in line. I've been waiting three months. Speaking of which, i need to call then about that tomorrow...
Old Dec 19, 2001 | 12:11 AM
Toadman's Avatar
Nomad Mod
Good help, Dclin..
I've got 245/40's in front not by choice so I'm extra careful..
c0rpse
16
Sep 25, 2015 11:33 AM
