To T-78 or not T-78, that is the quesiton
Old May 27, 2001 | 08:26 PM
Roy Johnson, Jr's Avatar
Question To T-78 or not T-78, that is the quesiton
I'm going single. I really think I want a T-78. I want a turbo that makes phenomenal power, but also is streetable for daily driving. I'm wanting to have around 475 - 550 rwhp.
Is this the turbo for me? What do I need to know about all the ratios pertaining to exhaust, etc.??? Is there another turbo I should be considering?
Does a T-78 have a LOT of lag?? If so, is the end result worth it?
Any help will be greatly appreciated.
Also, anyone with a T-78, I'd love to know the power you've derived with it
'95 VR RX-7 R2 - New Engine w/ Street port, intake, dp, mp, cat-back, BOV, elbow, pulleys, Trust SMIC, Alcohol/Water Injection, i/c pipes, clutch, 9.5# fly, fuel pump, rising rate regulator, 1200cc Secondary Injectors, Power FC, Factory Rebuilt Turbos, 17# boost, HKS Twin Power, 10mm wires, NGK plat. plugs
Old May 27, 2001 | 11:20 PM
Mr rx-7 tt's Avatar
rotary sensei
Gordon, How much larger did you go than with the PFS street port ??? Is your port job also bigger than the usual KD street port ??? Thanks, Chris
Old May 27, 2001 | 11:50 PM
ONO13B's Avatar
If you can use irrigation type sprayers mate on your water injection you are gonna have a better lasting option i think. Injectors will rust! Try a spa pump switch that actuates when boost comes on and as for pressure regulation, im not really sure, maybe have numerous spray nozzles coming frmo the one pump, and depending on the amount of boost you run, the more nozzles that open, the more water you are spraying in.
Old May 28, 2001 | 11:27 AM
Cool
I have an aquamist system. I don't have it hooked up yet. My understanding from them is you want to install the nozzle closer to the intercooler outlet. This give the water/alcohol ample time to do its job...cool the intake charge. If you're spraying right at the throttlebody, that's not giving it enough time to do its job.
I hear of people running 22-25 psi on these single turbos. If your air/fuel is set fine as to reduce detonation, is this kind of boost ok on the apex seals? I'm running 2 mm 2 piece seals in my new engine (9,000 miles)?
Old May 28, 2001 | 09:59 PM
xtrme7's Avatar
Roy you don't want to go with a T-78 cause if you do I will be forced to do it too and I don't have the money right now.
Old May 29, 2001 | 11:58 AM
Astro's Avatar
Out of curiosity does anyone know the characteristics and potential of the t88 against a t78 and its streetability?
aleem
93 red touring
Old May 29, 2001 | 01:49 PM
Cool
gmonsen,
Is there a particular reason you want to put it there? You might want to call the place where you bought it and see what they think.
I just think it will do a better job cooling the intake charge if it's further down (closer to) the intercooler outlet.
Old May 29, 2001 | 03:02 PM
newRX7fan's Avatar
Gordon:
Based on your mods, it looks like you do road racing. Do you race or do time trials? With your setup it seems like you should blow most everyone else away. Do you ever get passed? By what??
Old May 29, 2001 | 04:48 PM
xtrme7's Avatar
gmonson- roy and I are friends but we live about 3hrs away form each other,when we get a chance we meet up every once in a while and I can't have him stomping my *** every time we do.
Old May 29, 2001 | 04:56 PM
ballitek's Avatar
as far as a t78 and making that power.
we have a car running a t78, and it makes 540 to the wheels and he drives the car everyday. of corse the boost controller is off everyday when driving to work and back,but it is deffinality possible.
Old May 29, 2001 | 08:14 PM
ONO13B's Avatar
My eventual plan is to get a Garrett GT40 ball bearing turbo
For my purposes that seems to be the trick, an eventual 400hp at the tyres is that aim aswell on pump fuel (98 octane over here is the highest pump fuel) i will have a large front mount intercooler and water injection
Old May 29, 2001 | 08:48 PM
xtrme7's Avatar
gmonson-I dont road race but I do alot of street racing.And I wish I would of went single but got too much money in this set up, I will have to wait a while but it will happen. Also I am originally Reading Pa. ever heard of it? Heres my signature
94 rx7 R2 Painted custom color,18in wheels& tires,pettit racing track pro springs Rebuilt motor,rebuilt turbos,new trans,Greddy FMIC,Greddy BOV S- type,Greddy elbow,Greddy turbo timer,Greddy underdrive pullys,Greddy PE exhaust,enfeni Y-pipe,HKS megaflow intake,RP. down pipe,straight pipe,Apex power FC,1200cc injectors,highflow fuel pump,ACT street strip clutch and 8.5lbs flywheel
Old May 30, 2001 | 08:00 AM
It's on its way !! I went ahead and purchased the T-78. I wasn't going to buy one this quick, but I feel like I got a good deal.
Can anyone tell me what the factory AR is on this thing? The place I bought it from said 17 cm??
Is there anything I need to know about this thing when it comes time to put it on? Where have problems occurred? Anything to know ahead of time?
Any help is appreciated.
Old May 30, 2001 | 09:47 AM
xtrme7's Avatar
NO! send it back
Old May 30, 2001 | 11:07 AM
Cool
xtrme7,
I am looking forward to our next rendezvous
T-78 ON THE WAY !!!
Old May 30, 2001 | 08:01 PM
xtrme7's Avatar
Roy and Marshall you both make me sick.
Old May 31, 2001 | 12:26 AM
Marshall's Avatar
Roy,
Its an awesome kit, sounds like you have just about everything, but....The 1200cc's aren't going to cut it for 475-550 rwhp and I'm not totaly convinced of the PFC's abilities to handle massive hp. The learning curve is still pretty large with them and APexi could give a rats *** (or so its seems with there customer support). Details are sketchy as to whether it will handle 1600 cc injectors as well.
I'd set it up conservatively for 400-420 rwhp (15-17 psi) at first with the 1200s and PFC. Over 400 rwhp in a 2900 lb car is freakin scary as you will soon find out. 550 rwhp on a daily driven basis is goin to be pretty tricky (and also useless in anything but 4th and 5th gear). I'd ask Pluto (Steve Kan) about realistic pump gas hp goals.
Good luck! I just ordered the XS T04E kit, so maybe sometime we can meet up and see how they compare.
Old Jun 1, 2001 | 02:44 PM
Cool
Just exactly how bad is the T-78 lag? Are you waiting for days for it to come on line? If you race from a dead stop will you always be playing catch up?
T-78 ON THE WAY !!!
Old Jun 1, 2001 | 03:18 PM
Marshall's Avatar
LOL! A dead stop with a T-78 and street tires...you might be able to tune an AVC-R to bring on less of a hit in the lower gears. But 1st and 2cnd will probably be useless without at least an r compound tire (marginal) or DOT slicks(better).
I rode in a T-78 Supra and the lag was not all that bad...a little hesitation then blast off.
Gmonson, how is your 1st gear traction on the street?
Old Jun 1, 2001 | 03:34 PM
Stevil's Avatar
Roy,
I put my aquamist nozzle in the beginning of my IC pipe after it exits the IC. I went to an aluminum helo-weld place. they added a thick piece of alum on the pipe, plus tapped it and inserted my nozzle. All for $30. This is the closest place to place it after the IC. I am running twins, but will post results once all is tuned.
Steve
Old Jun 4, 2001 | 03:47 PM
Cool
Just canceled the T-78 order. I'm getting too many conflicting opinions on this thing. I want to be comfortable with my purchase before spending that kind of money.
I wish someone could list the different turbos available and give listings of approx. max HP, description of the lag (excessive, minimal, like stock, etc.), price range of kit, additional items needed to support the turbo (in addition to what I currently have listed below), etc.,etc.
I would like anywhere between 400 - 450 rwhp. By the time I got done with the T-78, I would have spent over $6,000 (including turbo) just in parts, no labor.
There's gotta be a great kit that can give me this kind of power that will work with the mods I already have. I was paying $3,345 delivered on the T-78. What other kits are available in this range?
H E L P ! ! !
T-78 ON THE WAY !!!
Old Jun 4, 2001 | 05:48 PM
RX Steve's Avatar
I just bought a T61 from machinehead. Two grand and he is paying shipping. Includes a wastegate and exhaust manifold. You can check it out on this site in Parts for sale. I can handle the rest. Could have done the exhaust myself but the price seemed good with it so WTF? It aint a T78 but it should have power in the right rpm range for me. I have no intetion of drag racing or turning 9 grand in my car. I am ordering the Haltech as soon as the Group buy guys decide who to order from. I have a project ahead of me huh?
I was hoping to have crispeed go over my motor (it was Pettit bridgeported and built 20,000 miles ago) but he did not return my calls so I guess he don't want any more work? I can understand that cause I don't need any more work now either. No hard feelings. I will probably just throw the motor back in as is once I repaint the engine bay and tidy it up a bit.
Roy, I am kinda surprised at your change of heart. Are you going to look for something more civil for the street?
Steve
Old Jun 4, 2001 | 07:55 PM
CrazyCanuck's Avatar
I wouldn't give up on the T-78 so easily. The lag is not bad at all. It's true that 1st (and second if you run over 10lbs.) require feathering the throttle to avoid wheelspin. Anything over 4000rpm in first and the tach just jumps to 8000! It's wicked! The top end rush though is bloody amazing. Launching the car requires some practice but I found it easier to launch than my non-sequential setup was. I figure it's better to have too much power than not enough... An AVCR to control boost by gear wouldn't be a bad idea but it's quite costly. I don't regret going with the T-78 for a second. Maybe if you can get a test drive in one you might be swayed...
Old Jun 4, 2001 | 10:35 PM
Astro's Avatar
So would you let me test drive yours if i came to ottowa?
hehe
did you ever get the pm i sent?
aleem
93 red touring
