Resistors for injectors?
Old Mar 14, 2005 | 03:09 PM
ImprezedRS's Avatar
Damnit, steel doors hurt!
I'm going to run some low imp injectors on my high imp car, ok i have looked at 2 webpages and have gotten 2 different resistors to use, one said use 10 watt 10 ohm resistors and the other said 20 watt 10 ohm resistors. Also I found the 10 ohm 10 watt resistors at radio shack but not the other, also they were pretty big to, any body got a pic of what they should look like and which is the correct one to use? Thanks for your help.
Old Mar 14, 2005 | 03:34 PM
Aaron Cake's Avatar
Engine, Not Motor
Doesn't matter. Both 10W and 20W will do the job. It's hard to describe what they look like. Generally, resistors 5W and larger look like little ceramic bricks with a lead out each end.
Old Mar 14, 2005 | 03:40 PM
ImprezedRS's Avatar
yeah these where about 1.5 inches long and .25 inch width, one wire coming out each side. thanks for your help, going to go buy them then.
Old Mar 14, 2005 | 03:43 PM
HAILERS's Avatar
HAILERS
The original ones in the solenoid resistor package are pretty large also. Attached is a jpg (hopefully) of the original with and without the aluminum cover over them. http://www.teamfc3s.org/forum/showth...threadid=33353
Those are 6ohm in the factory package. Ten is just fine. RadioShack.....10ohm white bricks....one per injector.
Old Mar 14, 2005 | 05:31 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
I used the radio shack ones and havent had a problem yet. Come 2 in a package and are very cheap.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
