Renesis into 1st gen?
Old Aug 7, 2003 | 08:44 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
ok... I know you'll probably see a ton of these threads as time goes on, so what the heck...
Ok, I *may* have a line on a Renesis from an Rx8 already... They're going to be the 1st to go 20b.. What all woudl it take to put this in a 1st gen?
Does anyone know how the engine mounts work on the Rx8?
It'll be run with a standalone, think there would be any shot at keeping the dual length intake track?
How about the tranny? I know the bellhousing bolts are the same, but any clue on the mounting points?
Ah so much stuff... so much stuff...
Old Aug 7, 2003 | 08:49 AM
rx7gslse's Avatar
and yes, I do know that most of this stuff would be custom, but I'd bet it can be done...
I just wanna know how easily?
Old Aug 7, 2003 | 09:00 AM
hondah8er's Avatar
mazdaspeed 3 coming soon
Why would you need a standalone unless your going to modify the **** out of it? You already have 250 hp. Just do intake, header and full exhaust. In a car that weighs 2300-2400 lbs you'll be rocking. And reliable n/a power.
Old Aug 7, 2003 | 10:13 AM
rx7gslse's Avatar
because the line on the motor I have doesn't come w/ an ECU...
they're disecting the ECU I beleive...
Old Aug 7, 2003 | 10:15 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
Well, I think that the FD transmission will fit it, because that's what Mazda uses for the low power model in Japan, so that covers the tranny. I'm not sure about what the engine mounts are like, but the basic casting of the rotor housing is the same any run of the mill 13B. Fuel management is way over my head, so I can't speak to that, but if you could get the wiring diagram for the RX-8 and took your time, I don't see why you couldn't use the factory management system.
Old Aug 7, 2003 | 10:28 AM
rx7gslse's Avatar
yeah, the housings are basiaclly the same... no worries there..
Fuel and engine management aren't going to be any different for the Renesis than any other 2 rotor.. Add fuel, adjust timing, maps etc accordingly. Coltrolling the port openings may be a bitch & a half depending on how they are actuated, but I'm sure this can be accomplised with a coupel RPM actuated switches & solenoids..
This one comes with teh tranny, so I'll do my best to utilize the 6 speed box. already all bolted up, and I wouldn't have to worry about any sort of custoom clutch/flywheel or anything.
I was wondering if the Rx8 motor mounts off the front or rear of teh block and I beleive it goes onto a custom subframe a-la the FD. I shoudl have looked closer at the ones we had out with us last night... http://www.rotarycomponents.com/pics/080603/080603.html
Old Aug 7, 2003 | 01:04 PM
rx7gslse's Avatar
ok, nevermind... I'm not gonna blow that much $$$ for only ~200 at the wheels.. no matter what teh gas mileage..
If anyone else wants to run on this lead, be my guest...
http://www.rx8forum.com/showthread.php?s=&threadid=7170
Re: Renesis?
Ok, check this out, the renesis engine is worth in the dealers, with out the intake, nor headers, 5,700 ..... Now, i can give you the engine with the intake, the headers for 5,000
Second, the six speed tranny in the dealers is worth 4,300 now i can give it to you for 3,500.
I'm saving you a total of at least $ 2000 if you add the intake, and the header to it.
[/url]
Old Aug 7, 2003 | 05:52 PM
ioTus's Avatar
'84 5-letter
Renesis engine mounts are located on the middle plates, one between the rotor housings, and one on the front plate i believe.
very odd.
not sure what tranny would bolt up.
not sure if the se oil pan and front cover trick used for the TII would work, either...
Old Aug 7, 2003 | 07:23 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
the 6 speed is nice... try getting that and get the rx-8 driveshaft and cut it if its too long... i heard its carbon fiber or light weight material... keep that intake is incredible too...
Old Aug 8, 2003 | 01:57 AM
Manntis's Avatar
add to cart
Dammit! I can't register in the RX8 forum for some reason.
One of you already registered, please have the chap email me at info@rotorhead.ca with details on buying that Renesis/Tranny
Old Aug 8, 2003 | 03:29 AM
REVHED's Avatar
Hunting Skylines
Don't just assume the Rx-8 ECU would even work in another car. There's a good chance the ECU is intergrated into so many sensors and things throughout the car that it won't even run without everything hooked up. Even the JC Cosmo ECU is a nightmare to make work right in another car and it's over 10 years old.
Old Aug 8, 2003 | 04:04 AM
ioTus's Avatar
'84 5-letter
yeah, you wouldnt want the seat camber-adjust sensor to set off the dummy :rollseyes:
there is SOOOO much electrical **** in those rx-8's
Old Aug 8, 2003 | 07:12 AM
inittab's Avatar
I read your email
One of you already registered, .....
I think you did manntis. When I searched for manntis on the RX-8 forum the website link was to your rotorhead.ca site. Maybe you were drunk at the time. Isn't there a way to recover passwords by submitting your email address? Just a thought.
Old Aug 8, 2003 | 09:24 AM
rx7gslse's Avatar
ha!
yeah, I suspected that your above all other people would be all over this one...
I decided that it wasn't going to be worth the ~$10k to finish out this projec and only have about 200+ at the wheels...
I'll take the crapp gas mileage and continue along the turbo route...
Old Aug 8, 2003 | 11:17 AM
onepointone's Avatar
i say what i want
****.. 10k? cought20bcough
Old Aug 8, 2003 | 11:39 AM
j9fd3s's Avatar
Community Builder
the renisis has a one peice water pump front cover deal, it may or may not swap to a 1st gen setup
mike
demetlaw
Oct 2, 2015 06:22 PM
