Best Dual Pulley Ever Gain 50hp
Old May 13, 2003 | 02:38 PM
1984se's Avatar
Ryan
Whats the best dual pully? i'm debating between HIGGYS ROTOR SHAPED ONE, MAZDARACING'S UNDERDRIVE PULLY that supposedly ads 14hp, OR mazdatrix.
Anyone suggestions what have you used????
Old May 13, 2003 | 02:50 PM
WackyRotary's Avatar
standard combustion
I highly doubt the 14hp. Its more like 5-10hp. I can't feel the difference, which is well with in the realm of imaginary hp gains. There is a horsepower gain, but so low its not main reason to get a underdrive pulley on a rotary you intend to push hard.(6000+rpm often)
The main reason to get one is to reduce rpm on the water pump and alternator, and a side-effect is slightly faster reving. The water pump tends to cavitate at the upper end of the rpm range in stock form, and underdrive pulley will eliminate that issue and make the pump last longer. You shouldn't have any cooling issues or voltage problems at low rpm if everything is in working order. Some people claim to have problems at idle with higher temps and lower voltage, but I don't.
Old May 13, 2003 | 02:55 PM
kuhlrx7's Avatar
Unconfirmed
horsepower is more like 2-4hp gain or 2% percent you probly wont feel it. I like higgys one, I am probly going to get it for looks.
Old May 13, 2003 | 03:35 PM
1984se's Avatar
Ryan
Yeah same here. I mean if it dosen't do that much and I'm not racing. Just good ol STREET HI PERFORMANCE. I'd rather go with higgys....It looks so cool. WOW ! ! !
WACKYROTARY :
So is there any advantage in getting the underdrive or racing beat's pulley opposed to higgys. maybe theres a weight difference that will make a dramatic difference???
What would recomend?
THANKS RYAN
Old May 13, 2003 | 04:05 PM
Matt22's Avatar
Fear The RE
get the rotor shaped one, or if your cheap you can get one from what I recal as a chyrsler Minivan. I think it
was a V6 get to the junk yard man, will work for both
the 1st gen and 2nd gen. PM me if you have questions.
lates matt22
Old May 13, 2003 | 04:09 PM
standard combustion
I never heard of higgy's. I know the RB one is aluminum, which is what i have-a single sheeve. I don't have any slipping issues a lot of people complain about. Just take some sand paper to the pulleys so they grip good and have a new belt with the v-teeth, they hold just fine for me so far.
Old May 13, 2003 | 04:29 PM
1984se's Avatar
Ryan
http://rx7cz.net/shop/
Old May 13, 2003 | 08:20 PM
12aPwr's Avatar
this looks bad ***
Old May 15, 2003 | 02:08 PM
1984se's Avatar
Ryan
bump
Old May 15, 2003 | 04:56 PM
hIGGI's Avatar
Mine are machined from duralumin, weight is 100grams exactly.
Old May 15, 2003 | 06:15 PM
zaridar's Avatar
35r 13b first gen
that red one is sweet *** dude! Im geting one of those
Old May 15, 2003 | 06:21 PM
Manntis's Avatar
add to cart
If you want to go the inexpensive route, don't start bolting Chrysler parts into your car. This one is available for under $20...
http://www.rotorhead.ca/detail.php?adid=2
But Higgi's is better looking
Old May 15, 2003 | 06:34 PM
1984se's Avatar
Ryan
NO, that one's WACK. it doesnt have a rotor on it. WACK!!!!!J/K MANTIS........I ve already sent HIGGI $$$ I GOT THE SILVER ONE..
Old May 15, 2003 | 06:37 PM
unreality's Avatar
Always broken.
Well, the rest of my engine bay is boring looking and dull, if I went and got a shiny red pulley, it would look out of place =P
I'd be compelled to shine everything, and the gold one looks fine to meee ; )
I guess if my car was a little prettier under the hood I'd go for Higgi's though
Old May 15, 2003 | 06:43 PM
1984se's Avatar
Ryan
they come in different colors i think black too just get that one:
Hey
My pulleys are not underdriven, price is $40 USD shipped, banking info is
same and colors to choose from are :
black
blue
red
silver
yellow
gold
purple
YOU'LL be COOL
Old May 15, 2003 | 07:05 PM
what the ****?!?!
At first I thought the thread was about main pulleys..... you know the lower one thats bigger! Then there is all this talk about alternator pulleys.... now why the **** would you want to slow the alternator? I havent found a reason for that yet........
And this wont free up hidden hp, only extra wieght!
The main pull would free up, since its directly on the drive line when the clutch is engaged...... like adding a light fly wheel, or lighter rims/tires, same effect....
Anyways, what was this originally about? alternator or main pulleys?!?!
Thanx, Laterz, Andrew.
Old May 15, 2003 | 07:20 PM
Gregs's Avatar
oh my god... this thread screams uncle bens....
rotorheads pulley is less than half the cost and your saying it dosnet look good and isint bling
lol
-greg
Old May 16, 2003 | 11:02 AM
1984se's Avatar
Ryan
Originally posted by 79+80+84_rx-7
what the ****?!?!
Its about the dual pulleys when you remove your air pump.
About underdriving the alternator its also something with the waterpump. They explain it on www.mazdaracing.com
"oh my god... this thread screams uncle bens.... "
what do you mean uncle bens
"rotorheads pulley is less than half the cost and your saying it dosnet look good and isint bling"
no, im not saying it looks bling. for sure its blingits OG LOOKING
but look and the BEAUTIFUL ROTOR SHAPED ONE
WOW ! soo cool.
anyways i got it already I'll post you guys when it comes in.
Old May 16, 2003 | 11:32 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
It takes more power to drive two belts than one.
Old May 16, 2003 | 11:37 AM
1984se's Avatar
Ryan
"It takes more power to drive two belts than one."
so your saying the adding a DUAL pulley will result in loss of HP cuz theres more power into truning the belts!?!
Old May 16, 2003 | 12:06 PM
Wankelguy's Avatar
Not necessarily.
It depends on the drive ratio, but given the same diameters, it will take more power to turn two belts vs. one due to the increased friction. Look at what people run on race cars, mostly single belts that are narrower than stock. Just a little something to think about.
Old May 16, 2003 | 12:08 PM
Manntis's Avatar
add to cart
yes and no. Dual belts will take a bit more power to turn than a single belt, but a single belt can slip far easier and allow your waterpump to stop pumping, thereby frying your engine.
Old May 16, 2003 | 12:24 PM
1st7heaven's Avatar
Manntis is right!!! Also, one time when I was racing, one of the belts broke on me......I didnt know it until after the run.......hence I was able to finish the run!!! As much as we spin our cars up(rpms) the belts tend to not last, I would never run a single belt!!!
my .02
Old May 16, 2003 | 12:48 PM
1984se's Avatar
Ryan
Well i really have no choice then i will be removing my air pump. So i need to go dual pulley and belts. Anyone know of the other way and just hooking up a belt to I think the AC pulley or somehting like that.
Old May 16, 2003 | 04:09 PM
Wankelguy's Avatar
Yes, two belts give an added measure of security in case one breaks, and they make more contact with the water pump pulley. That does not change the fact that it takes more power (albeit slight) to drive them, and since this thread was about belts and horsepower, I figured I'd address that issue specifically. FWIW, I've run a single belt for many years and never had a problem. I use quality belts made by Gates, or Mazda factory belts made by Mitsuboshi and keep them tight.
The biggest mechanical advantage is gained by using a lightweight, smaller diameter main pulley and a single narrow belt, though.
