Are our O2 Sensor wires Sheilded?
Old May 3, 2007 | 12:06 PM
StarScreaM2k1's Avatar
Rotax?! WTF is a Rotax!?
Trying to install a A/F Gauge (spare me any banter about it not being useful, i basically got it for free) and i have to get a O2 Sensor signal to it, i dont wanna butcher the stock harness. I was wondering if our O2 Sensor wires (in the enginebay) are sheilded? Because i can cut that and get the signal from there but i want to kknow if that would endup screwing with the signal.
Thanks!
Old May 3, 2007 | 12:16 PM
SpooledupRacing's Avatar
you shoudl be 100% fine.. if u are unsure u can buy some heat shielding at most shops for a couple bucks... buy spark plugs wire shielding here its only a couple bucks
Old May 3, 2007 | 12:32 PM
Thanks a lot Spooledup! Appreciate your help!
Old May 3, 2007 | 01:15 PM
Digi7ech's Avatar
I break Diff mounts
The majority of the wire is shielded with a ground mesh which connects into the harnesses ground.
It stops a couple inches from each end. So you can tap in before it starts near the ecu.
Old May 3, 2007 | 02:18 PM
HAILERS's Avatar
HAILERS
Here's a picture of the 02 GREY wire as it comes thru the bulkhead b/t the engine and passenger. Shielded? Yes.
Can you use a normal piece of wire. Probably so. Try to keep it seperated from the other wiring the best you can and it'll work ok.
rgordon1979
40
Mar 15, 2022 12:04 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
mulcryant
Sep 9, 2015 05:24 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
