Which Wire To Splice On Fuel Pump?
Old Jun 19, 2007 | 09:00 PM
RoTa7's Avatar
just a quick question, i couldnt figure out which was the best wire to splice on the fuel pump harness for my kill switch.
thanks 88 gtu
Old Jun 19, 2007 | 11:25 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
Black wire with white stripe, but double check the FSM in case the wire colors varied from year to year.
Old Jun 20, 2007 | 02:57 AM
RoTa7's Avatar
is that one the signal wire?
Old Jun 20, 2007 | 03:47 AM
NZConvertible's Avatar
I'm a boost creep...
There are two signal wires to the circuit opening relay, so your switch needs to intercept the power instead. The B wire (black with a white stripe) is the power supply and the Fp wire (blue with a red stripe) goes to the fuel pump. The switch can go into either of these wires, it doesn’t matter which. Simply cut the wire, extend each cut end to your chosen switch location using the same or thicker gauge wire and terminate them onto the switch. Note that the STA wire is also black with a white stripe, but it’s thinner. Make sure you get the right wire.
Snoopy FD
Dec 8, 2015 01:45 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
ChrisRX8PR
Oct 18, 2015 04:01 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
