Launched the car, heard a THUNK!
Old Feb 14, 2003 | 02:39 PM
J-Rat's Avatar
Alcohol Fueled!
Angry Launched the car, heard a THUNK!
Let me guess... I broke a diff mount? Everytime you hit or release the gas pedal, there is a big CLUNK in the right rear area of the car.....
*** a Duck...
Old Feb 14, 2003 | 02:42 PM
banzaitoyota's Avatar
What Subscription?
yep: Rear diff mount I have some used ones cheap
Old Feb 14, 2003 | 02:44 PM
87turbo2's Avatar
replace it SOON! I have broken u joints on drive shafts by not getting it done quickly.
Old Feb 14, 2003 | 02:57 PM
jacobcartmill's Avatar
just dont care.
yep, broken diff mount my friend.
Old Feb 14, 2003 | 03:58 PM
J-Rat's Avatar
Alcohol Fueled!
I wonder if the mounts on my 86 N/A will fit my 88 TII?
Old Feb 14, 2003 | 04:39 PM
Dyre's Avatar
Your Opinion is Wrong
Dont know- But the comp mounts are only $60 brand new-
Old Feb 14, 2003 | 05:15 PM
J-Rat's Avatar
Alcohol Fueled!
I just want to get the damn thing back on the road..
Old Feb 14, 2003 | 05:41 PM
dr0x's Avatar
pei > caek
Im not sure if the 86 NA mounts would work. Do the open difs and lsd's have the same mount positions?
Old Feb 14, 2003 | 05:45 PM
RangerJoeEOD's Avatar
that sounds the same as when my U Joint went out, if thats the case youll need to Pull the whole shaft out. I would get under the car and shake the u joints if there's any movent betewwn the jounts thats your problem. From all thoes track trips i guess.
Old Feb 14, 2003 | 09:28 PM
J-Rat's Avatar
Alcohol Fueled!
I dont know...I already paid for the ones from banzaitoyota, but I want the car back on the road. I need the garage for the S4/S5 swap on another car
Old Feb 14, 2003 | 10:03 PM
J-Rat's Avatar
Alcohol Fueled!
how hard are they to replace?
Old Feb 14, 2003 | 10:05 PM
What Subscription?
I'll ship yours out Saturday. You need to drop the rear subframe. BELIEVE ME ITS EASIER!!!!!
Old Feb 14, 2003 | 10:22 PM
J-Rat's Avatar
Alcohol Fueled!
you know what? its the damn front mount, not the back ones
Old Feb 14, 2003 | 10:27 PM
J-Rat's Avatar
Alcohol Fueled!
Drop the rear subframe? What the hell is that?
Old Feb 16, 2003 | 04:44 AM
ReZ311's Avatar
KM48 Burnout
yeah. the differential has a front mount. That is what usually breaks. If you keep breaking them, WELD It.
Old Feb 16, 2003 | 03:01 PM
J-Rat's Avatar
Alcohol Fueled!
It was welded, the weld broke!
I already ordered the Mazdatrix race mount.
Jarrett
Old Feb 16, 2003 | 03:20 PM
Jimmy325i's Avatar
No longer cares
Must've been a crappy weld...
Old Feb 16, 2003 | 04:23 PM
87turbo2's Avatar
When I had my side draft dellorto on a streetported motor, I broke 2 good welds after the "normal" mount was replaced 2 times.
Old Feb 16, 2003 | 07:09 PM
Jimmy325i's Avatar
No longer cares
Mines welded on two sides using substantial plate to bridge the gaps. Breaking is not a concern of mine.
Old Jan 9, 2007 | 09:28 AM
TweakGames's Avatar
FD pro licensed driver
Do you have any pictures of that setup? I need to weld mine up and am looking for examples. THANKS!
(EEK didnt notice how old this post was hehe) Anyways, anybody have pix of a good double welded diff mount?
Old Jan 9, 2007 | 09:35 AM
SukMy7's Avatar
THE 7 CANT LOSE!!!
replacing that front mount is a bitch drop the whole subframe it will actually save you some time and alot of headache.
Old Jan 9, 2007 | 09:43 AM
TweakGames's Avatar
Well the plan is to just weld it, but I need some example pictures before I just jump right into it.
Old Jan 9, 2007 | 11:18 AM
classicauto's Avatar
Crash Auto?Fix Auto.
Pinion snubber and a comp. mount.....
Old Jan 9, 2007 | 11:49 AM
TweakGames's Avatar
ooooorrrrr weld and not drop the rear. Weld it is. gg
Old Jan 9, 2007 | 02:09 PM
papiogxl's Avatar
What's the point??
Orrrrr don't do it half-assed and do it the right way pinion snubber and comp mounts. I don't think I've heard of this setup breaking, but yet I've heard of several welded ones snapping. Also, the is less vibration with a proper mount.
