13B-RE questions
Old Aug 31, 2004 | 11:11 PM
JDriftM's Avatar
Progressive Rotorhead
13B-RE questions
I know it's been over. But I do want to know if a stock TII ecu from a S4, maybe remapped would control a 13B-RE with the twins on non-sequential or if maybe putting on a S5 turbo would work? I would like to avoid a stand alone, at least for a while. I've heard that the stock ecu can handle the 13B-RE as it comes from Japan with sequential turbos, but not very well. I want to know if non-sequential or a S5 single would work?
Thanks,
J
Old Sep 1, 2004 | 04:30 AM
Hey dude,
The S5 ecu should work , if using a S5 turbo on the engine. If you want to run the twin turbos then I think you may have to use the stock Cosmo 13B-RE ecu, N390 with the auto tranny it came with. If you're interested plz let me know as I have one for sale.
Old Sep 1, 2004 | 10:17 AM
JDriftM's Avatar
would a s4 ecu work with the s5 turbo on the RE since that is what most s4 guys swap to is the s5 turbo on the 13BT?
Thanks,
J
Old Sep 1, 2004 | 05:55 PM
JDriftM's Avatar
I also wonder, does any of the S4 TII parts swap over? If i was to change out the CAS and what ever other sensors are on the RE for S4 ones, would that maybe make it compatible with a S4 with S5 turbo?
I am looking to buy an engine for my 3rd S4 FC and i would like the larger ports that the RE comes with but the economical and streetable stock computer with maybe a Rtech7 chip and/or an ApexI SAFC II.
Thanks,
J
Old Sep 1, 2004 | 07:12 PM
RETed's Avatar
The motor doesn't drop in.
A stock Cosmo ECU is not going to work properly.
A stock Cosmo ECU remapped to get rid of all the stupid electronics error codes might work but not very efficiently.
A stand-alone EMS is highly recommended.
The Cosmo 13B-RE CAS is the same as all FC3S CAS.
It sounds like you're trying to do this on a budget.
I don't recommend going this route.
You're going to end up with a lot of car parts laying around.
-Ted
Old Sep 1, 2004 | 07:30 PM
JDriftM's Avatar
Thanks. Nix that then.
J
Old Sep 3, 2004 | 02:54 AM
TonyTurboII's Avatar
Glock Lover
Not to mention the PITA time yo would have with the two different TPS sensors.
Old Sep 3, 2004 | 02:59 AM
RETed's Avatar
If electrical wires scare you, yes.
Cosmo motors run the same TPS as the FD3S.
They have narrow-range and full-range TPS' built into one unit.
It's easy to wire them to mimic the S5 TPS.
-Ted
Old Oct 16, 2004 | 03:17 AM
krackerx7's Avatar
-Ted
so lets talk about a TII ecu. I read alot about that but i havent read on one actualy running correctly, its all been talk and i heard this and that. I would actualy like to know how you would go about making it run right? because that seems to be a big draw to these engines but i cant find any solid info on it.
thanks
Old Oct 18, 2004 | 01:32 AM
krackerx7's Avatar
Old Oct 18, 2004 | 05:18 AM
RETed's Avatar
I would never do it that way myself.
I prefer Haltech EMS ECU's in this application.
-Ted
Old Oct 18, 2004 | 07:35 PM
krackerx7's Avatar
but if you where going to do it that way, how would you go about it?
Old Oct 18, 2004 | 07:42 PM
Rx_treme's Avatar
if you want to do it cheap to get it running just drop in a s5 ecu and harness.. theres only a few small things you need to change it over to make it work.
Old Oct 18, 2004 | 08:23 PM
krackerx7's Avatar
thats what i was wondering whatthey would be i know you need the run the turbo's non-seq but thats about it
Old Oct 19, 2004 | 08:13 PM
RETed's Avatar
With the stand-alone?
I'd go Haltech.
With the stock ECU?
I would never attempt one.
-Ted
Old Oct 19, 2004 | 08:56 PM
krackerx7's Avatar
i was talking stock ecu, what challenges would there be by using the stock ecu
Old Oct 20, 2004 | 03:12 PM
Digi7ech's Avatar
I break Diff mounts
Back up.
I have a guy which bought a 10th AE and has a comso dropped in the car.
This guy is a COMPLETE rotary newb!!!! I mean NEWB!
I told this guy he was stupid for getting the engine but it's too late.
He has no money for a EMS and needs it running soon.
So The TPS has kept us stationary/in holding position using the stock S4 ECU.
We're going to need to use an S4 TPS since it's a S4 car and ecu and harness.
I checked the TB and it is a bigger port as well so there goes my idea of using a S4 TB
He said the injectors were 550's all around. Is that right???? If so I assume the stock RE turbo will kill the engine quick using an FC ECU/fuel map.
Any way. Back on topic.
The RE TPS is a narrow/wide TPS and is 4 a pin.
Is it possible to use on a S4?
Also second option/maybe
Run as S5 so the TPS won't be a problem. BUT you now have the interior harness S4/5 problem.
If it's not possible to run the RE TPS then I guess we'll have to work with a S5 harness.
Old Oct 20, 2004 | 08:35 PM
RETed's Avatar
Cosmo TPS is identical to the FD3S TPS.
It has a narrow-range and a full-range TPS built into it.
You can just wire the narrow-range TPS to keep the S4 ECU happy.
Yes, the Cosmo uses 4x550 fuel injectors, all high impedence.
Good luck trying to get it to run.
-Ted
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
