Blue Connector
Old Mar 27, 2003 | 02:06 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
Blue Connector
I found a light blue connector near the thermostat/waterpump housing that was not connected to anything. Does anyone know what this connects to?
Old Mar 27, 2003 | 02:09 PM
rynberg's Avatar
It's not supposed to be connected, don't worry.
Old Mar 27, 2003 | 02:20 PM
dubulup's Avatar
development
EGR I believe, mine is not connected either.
Old Mar 27, 2003 | 02:41 PM
reza's Avatar
Its for EGR.
If its not connected, your stock ECU should lit up the engine check light.
Reza
Old Mar 27, 2003 | 03:16 PM
rynberg's Avatar
Originally posted by reza
Its for EGR.
Reza
That's only for California cars. I believe for 93-94 non-Cali and all 95s, the connector should not be connected to anything (95s don't have electronic EGRs).
Old Mar 27, 2003 | 03:21 PM
Sled Driver's Avatar
The Anti-Prius
Its for EGR.
Reza
Reza, you retard, what are you going to connect it too? It's an extra plug that just lays there.
Otherwise every 3rd Gen would have a check engine light on all the time.
Should we post a poll?
Plus this question gets asked everytime some newbie removes his UIM & pokes around (hose job comes to mind)
Old Mar 27, 2003 | 07:13 PM
duboisr's Avatar
If your car has an eletronic switch on the EGR and it is disconnected or broken from the heat , then the computor throws a code
Old Mar 28, 2003 | 08:55 AM
HDP's Avatar
HDP
Yep! That's me!
Old Mar 28, 2003 | 09:09 AM
HDP's Avatar
HDP
So it's not needed for anything? The reason I'm asking, the connector on my airpump is broken and this connector is an exact match (except color) to the one on it. So would there be any harm in cutting this connector off and soldering it to the airpump? Thanks in advance.
Old Mar 28, 2003 | 11:03 AM
reza's Avatar
me retard? wait a minute! how can you say that to me.
on my car I have that plug. When I unplug it, and remove the EGR, I have check engine light lit all the time.
that is what I am saying.
plus someone above also mention that its only for California. Now that I just remember there are two ECU version, one is for california, and one is non-california.
So perhaps that explain why the guy have extra plug.
He probably has non-cali ECU but he has cali wiring harness?
Old Mar 28, 2003 | 11:21 AM
Mahjik's Avatar
Mr. Links
Yes, you are correcet Reza. The '93 Cali cars do have the EGR so the plug is used. The '93 non-Cali cars do not have the EGR so that plug is unused.
BTW, I think he was saying "retard" in a joking manner.
Old Mar 28, 2003 | 01:08 PM
The Anti-Prius
Sorry if I offened you, that was not my intent.... well not fully. Mahjik was correct, I was joking about the retard comment. Since you have a Cali car I can see why you posted your reply.
But you do see this question asked alot!
Old Mar 28, 2003 | 01:31 PM
HDP's Avatar
HDP
Hello!!! What about the topic at hand???
Old Mar 28, 2003 | 01:35 PM
dznutzuk's Avatar
Uncontrollable drifter
All the cars have the same wiring harness, except for overseas vehicles. That's why it is present on all the cars, and there's no harm in cutting the plug off it fits and your sure that the car doesn't have an egr valve, just make sure to tape it up.
Old Mar 28, 2003 | 02:43 PM
reza's Avatar
yeap. i do see this question get asked a lot.
no problem sled driver.
i am just curious, i thought i answered it wrong.
my airpump connector broke too. I just replaced it with some connector from radio shack.
make sure you get the polarity right.
reza
