(ELECTRICAL) fusable links
Old Mar 21, 2002 | 07:11 AM
DONNA's Avatar
Question (ELECTRICAL) fusable links
what does each link control, 1,2,3 thanks,,,,,
Old Mar 21, 2002 | 10:14 AM
Directfreak's Avatar
I am a Jeeper Now.
I think it says it right on them
On my SE, I believe it's
Headlamp Motors
Headlamps
Fuel Injection.
On your GSL it may be slightly different,
Old Mar 21, 2002 | 12:20 PM
FJ's Avatar
FJ
On the GSL, top to bottom, it's
Headlight motors (brown)
Main (black)
Headlights (brown)
The -SE has a separate block with two links
Injection (green)
computer (brown)
-John.
Old Mar 22, 2002 | 10:19 AM
hanman's Avatar
Donna,
Do your self a favor and replace the links with a fuse block from a second gen, or 626, probe or whatever.
hanman
Old Mar 22, 2002 | 04:15 PM
mar3's Avatar
Administrator
It's not that critical...I've been running the TII 80 amp alt in my '80 for about a year now and no problems at all. I did replace the fusibles with new ones, though...
Old Mar 22, 2002 | 06:40 PM
hanman's Avatar
My thoughts are the original links were not designed to handle the peak output from the newer alternators. Plus, it is far easier to troubleshoot a fuse than a link. And as an additional bonus the second gen fuse block gives you more flexibility in adding aftermarket accessories i.e. foglights etc.
just my opinion,
hanman
Old Mar 23, 2002 | 10:27 AM
mar3's Avatar
Administrator
They seem to be handling the peak power of my 80 amp alternator quite fine and it's easier to replace the fusible link than do a wholesale changeover with all that cutting and splicing and soldering and etc.....
Old Mar 23, 2002 | 12:08 PM
hanman's Avatar
It took me 30 minutes, and it looks stock. I thought it was very easy.
just my opinion though,
hanman
Old Mar 23, 2002 | 12:11 PM
I am a Jeeper Now.
hanman
Post a Pic..I might do the same soon..
Old Mar 23, 2002 | 12:40 PM
mar3's Avatar
Administrator
My thoughts exactly...time to put up or.....
Old Mar 30, 2002 | 11:12 PM
I am a Jeeper Now.
just my opinion,
hanman
hanman
Sorry to bring this up Hanman, but I will be doing something similar to this in the near future. Can you PLEASE post pictures of this setup?
Thanks
Old Mar 30, 2002 | 11:46 PM
gonzz's Avatar
post pics so we all can see..
Old Mar 31, 2002 | 12:08 AM
V8kilr's Avatar
hanman is now scurring to gather up some pics.
i'll posts pics of mine when i finalize my direct fire setup,
i just used three breaker boxes but plan to swap them over to 3 agu style fuses "60 amp" in see through 4-10 gauge holders.
Old Mar 31, 2002 | 12:13 PM
hanman's Avatar
Hey,
I just looked at this thread again, I will take some pics and figure out how to post them.
hanman
Old Mar 31, 2002 | 07:56 PM
V8kilr's Avatar
in the meantime
/\TTT/\
Old Apr 1, 2002 | 09:47 PM
I am a Jeeper Now.
Bump.
Old Apr 2, 2002 | 01:10 PM
I am a Jeeper Now.
BUMP.
Waiting for Hanman to post pics...
Old Apr 2, 2002 | 01:13 PM
mar3's Avatar
Administrator
Hey,
hanman
Right now, he's sitting in his garage with the 2ndgen fuse box in his hand trying to figure out how whether he's going to make it work or whether he should stick it in there with double-sided 3M tape and make it look like it's done for real for his photo shoot....
Old Apr 2, 2002 | 01:19 PM
I am a Jeeper Now.
Old Apr 2, 2002 | 11:22 PM
V8kilr's Avatar
oh **** thats too much,
he probably got to the part were the tape came into play and started to think,
"**** now i need to find some spare wire to run to this thing,
oh **** it,its never gonna fly,I'll just pretend like i dont see the thread"
I promise pics of mine soon enough,
my problem is im converting from my breakers that i installed to agu fuses,
the fuse holders are roughly $5.00 a piece,
nice high amp fuses are $5.00 a piece
but the highest amp fuse i have on hand is a 50a,
and the highest i can find is a 60a,
i want 80a-100a
so i might not use the agu fuses and instead use waffle fuses,
a bit more expensive though.
Old Apr 2, 2002 | 11:28 PM
riffraff's Avatar
smog nazi destroyer
why do you want fuses with that high of an amp rating?
granted they are probably not going to blow, but if by some chance they do, your wiring will probably go with it
Old Apr 2, 2002 | 11:29 PM
riffraff's Avatar
smog nazi destroyer
ignore that last post... for some reason i was thinking that we were talking about the regular fuese, not the fuseable links.... guess it would help if i read the topic
Old Apr 2, 2002 | 11:33 PM
V8kilr's Avatar
yep,
that and the fact i'll be replacing my fading 1st gen alt with a 2nd gen high amperage alt.
Old Apr 3, 2002 | 12:46 AM
mar3's Avatar
Administrator
Thought I'd toss this in for you so you won't have to search for it plus a little bonus from the South Forum...
The well-worn '89-'91 alternator into 1stgen RX-7 conversion diagram
7-sweetie and friends from the FD crowd in the Metroplex
One of these days, I'm gonna make the Starbuck's trip....
Old Apr 3, 2002 | 01:52 AM
hanman's Avatar
ok, I used velcro to get the damn thing to stick onto the strut tower, then I took the pics, now I can't figure out how to post pics!!
hahahaha
hanman
