Street port, beveled rotors - pictures
Old Dec 14, 2005 | 01:07 PM
SureShot's Avatar
Seduced by the DARK SIDE
The rebuild started right up.
It runs smoother than I expected. Almost no Idle lope.
The hardest part is keeping off boost during break-in.
The cause:
Template & layout:
Primaries - conservative to maintain high charge velocity:
Secondaries - your basic street port:
Exhaust - a little more clearance, a little earlier opening, same closing:
Rotor - bevels for earlier opening & later closing with the primary opening earlier than secondary:
Early opening:
Late closing:
I won't know about high end power until after the break-in.
Old Dec 14, 2005 | 01:10 PM
Parastie's Avatar
Mountain Rotary Mod
picture's don't seem to be working for me.
Old Dec 14, 2005 | 01:13 PM
SureShot's Avatar
I just finished cleaning up the typos.
Try again..
Old Dec 14, 2005 | 01:15 PM
550rwhprex's Avatar
Im Back Bitches
Who cut those rotors.. have you run them before....
Old Dec 14, 2005 | 01:19 PM
SureShot's Avatar
Me & my little dremmel - with some careful templating.
And - yes - I did lighten the counterweights also.
Old Dec 14, 2005 | 01:22 PM
TII: Judgement Day's Avatar
Qwiksillva
With a Dremel? Wow, so I could pull something like this off as well.
550rwhprex's Avatar
Im Back Bitches
i ask becuz I know the person who cuts them.. the right way and has proven them one the race track (GT-1 ) and on the street ..
Old Dec 14, 2005 | 01:23 PM
TitosToy's Avatar
very sleepy!!
is that plexiglass you used for the template of the rotor?
Old Dec 14, 2005 | 01:26 PM
TitosToy's Avatar
very sleepy!!
what yr are the rotors from? did you use the counterweight from a S5?
Old Dec 14, 2005 | 01:32 PM
SureShot's Avatar
It's all S5.
I cut side & face templates for the rotor bevels.
Careful layout - stop at the line.
Side seal support ridge is .050"-.060"
The templates are made from some .020" plastic sheet.
Easy to cut with scissors & very little parallax transfer error.
Old Dec 14, 2005 | 02:00 PM
gerbraldy's Avatar
wtf's a piston
I would love to see what it makes for power once it's broken in and boosting, keep us updated.
Old Dec 14, 2005 | 02:04 PM
RotaryEvolution's Avatar
Sharp Claws
you guys are ballsy cutting rotors by the seat of your pants. i hope the bearings don't prematurely fail due to an out of balance rotating assembly.
i would only try it in an engine that would never see more than 8k and was only run at the track a few times a year and wouldn't mind if the engine blew.
i am interested in how much this port phasing helps though.
Old Dec 14, 2005 | 02:11 PM
SureShot's Avatar
This is the origonal motor in my daily driver.
The temporary J-spec is now on the stand - in case this deal blows up.
So far - low end feels every bit as good as the J-spec.
Just a little torque vibration as it pulls up past 1200RPM.
I feel it only because my torque brace has very little cushion.
It's as smooth as glass up to 4K (well 5K once).
In a few weeks it will either look brilliant or stupid..
Old Dec 14, 2005 | 02:17 PM
J-Rat's Avatar
Alcohol Fueled!
Hey, someone has to be the pioneer! Keep us updated man!
Old Dec 14, 2005 | 02:22 PM
MattB's Avatar
MattB
who wants to bet it blows up?
did you get them rebalanced? or did you just kinda do it and hope it all works?
Old Dec 14, 2005 | 02:40 PM
SureShot's Avatar
On my budget - close has to be good enough.
I just took my time with the templates on all 6 faces, to make them exactly the same.
On initial startup I held various steady revs between 1K &3K with absolutely no vibration.
So it should be OK for at least a while.
The only vibration I get at all is a slight torque resonance at 1200 during acceleration.
Old Dec 14, 2005 | 03:32 PM
classicauto's Avatar
Crash Auto?Fix Auto.
even though it ran well, with min. vibration - how could you be sure wehen you put it back together?
did you wiegh the shavings you ground off?
just curious, this is some very in depth motor work for the setup you have...Im quite impressed. - nice work my you rotary playa
Old Dec 14, 2005 | 03:37 PM
Mordachai's Avatar
_
Awesome xperiment man,
Keep us updated,
I see you're in Jax, I have a buddy in north palm beach who works at a machinist shop. Maybe he can do some beveling for you (next time? will there be a next time?)
All he needs to know is what to change, he can program the machine, CAD and all..
I'll see if I can get his *** to post....
|M|
Old Dec 14, 2005 | 04:02 PM
Dom_C's Avatar
definetly excited to see the outcome of this. Keep us updated!
Old Dec 14, 2005 | 06:52 PM
rotariesrule's Avatar
uh, i don''t know what the big deal is this mod has been around forever.
Old Dec 14, 2005 | 08:13 PM
eriksseven's Avatar
Make Money.
Even if it has been around "forever", it's poorly documented and the people who run the custom beveled rotors are few and far between. Any documentation or progress that's posted is valuable in helping the next man decide whether or not he wants to undertake this type of modification.
Old Dec 14, 2005 | 08:19 PM
brent clement's Avatar
Fabricator and builder
Beveled rotors
Looks like you did a nice job. I've been itchin to do a set myself. I'll be milling mine but there's nothing wrong with the way you did it.Guy's way over think these things. Why would you need to rebalance and all that ****? As long as you cut each one the same they'll be every bit as balanced as before you did the mods. Hope it stands the test of time. Will you be taking it to the dyno?
Brent
Old Dec 14, 2005 | 08:46 PM
iceblue's Avatar
Passing life by
This is great. Jrats got it, someone has to test it for us :-D But anyhow I realy like how you showd the port opening and closing times with the rotors. Good work bro!
Old Dec 14, 2005 | 09:58 PM
sleeperfc's Avatar
MP T-70 = Fun
i want updates on this.
What math did you use to figure out how much weight to take off the counter weight?
What hp goals at what boost level using what turbo do you have planned for this motor?
Old Dec 14, 2005 | 10:57 PM
zeromage428's Avatar
BWAAA
thats some crazy stuff man.....how long do u think the engine will last with the rotors like that? normal life expetency?
