add coolant light
Old Mar 10, 2004 | 02:33 PM
jgrts20's Avatar
Who are you?
add coolant light
welp after driving it today also, my add coolant light keeps coming on/off!! my question is why is it doing this?
the overflow tank is full and i checked the radiator also, its full also!! the car has been in storage all winter and it didnt do this yesturday when i drove it!! suggestions please, i did a search also and cant really find my answer!!
oh the gauge reads normal, between 1/2 and 1/4.
Old Mar 10, 2004 | 02:35 PM
theone81's Avatar
Coolant sensor may be defective...
Old Mar 10, 2004 | 02:40 PM
gambone's Avatar
you need to know how to fill it, race the motor 2k or 3k with the cap off this will suck the level down and at this point add and put the cap back on and let go of the throttle, if the lite comes back start looking for that leak
Old Mar 10, 2004 | 04:19 PM
Csefiroth0's Avatar
My coolant light kept going on and off too... just a couple of days ago. There was a radiator leak.
good luck
-c
Old Mar 10, 2004 | 04:32 PM
NZConvertible's Avatar
I'm a boost creep...
Most likely air bubbles in the cooling system are responsible for the intermittent coolant level warnings. You need to use the bleed valve on the side of the upper radiator hose connection to ensure all air is removed from the system while filling. Follow the procedure in the FSM or Haynes.
Old Mar 10, 2004 | 05:02 PM
bingoboy's Avatar
Lava Surfer
also may be caused by a crummy connection on the sensor wire.
Old Mar 10, 2004 | 05:17 PM
domesttuner's Avatar
CVPI rules the road
maybe you should add coolant?
Old Mar 10, 2004 | 05:43 PM
shoneeko's Avatar
maybe the thermostat is bad. happened to me to that the overheat light kept going on. changed the water pump, and the thermostat, and the problem went away.
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
RPOdesign
Aug 27, 2015 11:42 PM
