T2 cranking but wont start
Old Nov 22, 2018 | 05:02 PM
Rotary Alkymist's Avatar
My mom lets me redline
Your timing looks off in that photo even though I can't see the points.
Old Nov 22, 2018 | 06:15 PM
Jake87fc's Avatar
This is with the marks on the bottom of the cas lined up and the pin lined up with the yellow mark (the one on the right). I made reference marks on the teeth so i could see it didnt move when installed.
Old Nov 23, 2018 | 09:18 PM
Maybe AFM? Is it plugged in?
Check for error codes. You might find something there.
Old Nov 27, 2018 | 08:51 PM
BrapMobile's Avatar
I was in a similar boat when I swapped in my t2 motor. Turned out I reversed the primary and secondary injector connections. Maybe you did too?
Old Nov 28, 2018 | 09:23 PM
Jake87fc's Avatar
I removed the UIM and the fuel rails and did a ziptie leak test, no leaks. .14 ohms on all injectors and 12v on all plugs. I followed the fuel lines and and it goes from a hard line on the firewall to the fuel pressure regulator -> right size of the secondary fuel rail -> primary fuel rail -> my fuel pressure gauge to a soft line that goes down to what looks like beneath the car. I couldnt see which one attaches to the fuel filter so ill jack the car up and see if i can figure that out tomorrow. And ill grab a picture of how the wires are hooked up to the injectors. If all this is right and the timing is right, what are the next steps to diagnosing why this wont start? I plan on going stand alone ecu later on but i want to get it running and clean it up first
Old Nov 28, 2018 | 09:32 PM
CryoSignal's Avatar
Bankrupt rotary
I recently rebuilt my s4 turbo motor and it gave me a ton of trouble starting. I had fuel and spark, though I didn't check the compression but it sounded good when cranking. After putting two pumps of 90w gear oil in the upper spark plug holes it fired right over. Sometimes rebuilt motors have trouble building compression, but after they run for a couple hours the seals break in and build compression.
Old Nov 29, 2018 | 08:11 AM
Jake87fc's Avatar
The fuel pressure regulator should be after the fuel rails right? And the return line comes out of the secondaries if im not mistaken. So it should go from the hardline on the firewall -> right side of secondary fuel rail -> left side of primary -> fuel pressure regulator? Im not sure if changing the direction of fuel flow would effect it or not
Old Nov 29, 2018 | 01:56 PM
CryoSignal's Avatar
Bankrupt rotary
Old Nov 29, 2018 | 02:47 PM
The line coming from your "fuel filter" goes to pulsation damper which is the right side of primary/ out of left side of primary/ in to left side of secondary/ through regulator/ to return line. It will not operate in reverse.
Edit: Cryosignal is right, especially since you aren't running the OMP you aren't getting a ton of lubrication which is important after a rebuild. You also have a 28.6% difference in compression tests. This is high and the book actually calls for a rebuild at that point.
Old Nov 29, 2018 | 03:45 PM
Jake87fc's Avatar
Once i verify the fuel lines are routed right ill put everything back together and pour oil into the low compression rotor and see if that helps with anything. Would about a lid of oil be enough? And would low compression be a reason for it starting with the timing advanced 5 degrees? With the cas set with the divots lined up it doesnt feel like it wants to start at all. Even when i give it gas
Old Nov 29, 2018 | 05:47 PM
CryoSignal's Avatar
Bankrupt rotary
I bought a hand pump that screws to the top of the bottle, and put two good pumps of 90w gear oil. Probably doesn't have to be that thick, I'm sure the 20-50W oil for the engine would work. Make sure the hose from the pump gets all the way in the spark plug holes or more is going to dribble down the engine than go into the chamber. Just to be safe I'd put oil in both rotors while your at it and start it with FSM timing specs. Once its running you can play with the timing using a light.
Old Nov 30, 2018 | 09:58 AM
DaBrkddy's Avatar
Smells like 2 stroke.
Are you sure it's not flooded?
If it's not flooded, are you sure the fuel pump is working when you jumper the test connector? What is the voltage at the pump? Where are you taking fuel pressure readings from?
Old Nov 30, 2018 | 12:33 PM
BrapMobile's Avatar
Have you pulled out your CAS and make sure it's lined up like this?
Old Dec 1, 2018 | 09:44 AM
Jake87fc's Avatar
I have tried the deflooding procedure many times with no luck. And i have a fuel pressure gauge hooked up before the primary fuel rail reading 40 psi.
Old Dec 1, 2018 | 02:30 PM
You need to pull codes as a process of deduction. Its one of the first things you should for plenty of reasons:
1. No wrenches involved.
2. Pinpoint an issue in seconds instead of hours perhaps days.
3. In the event that you don't have any codes to pull will hint to a mechanical issue.
4. The system was implemented to make a mechanics job much simpler.
It's there as a tool and it should be used. It costs about 10 bucks to fashion a tester.
Old Dec 1, 2018 | 02:39 PM
Did you indeed check to see if you AFM is plugged in? I think it'll spit out a code 08 for AFM. I know the car will have a really hard time starting without it plugged in.
Old Dec 2, 2018 | 11:10 AM
DankestKush's Avatar
have your tired holding the flapper on the AFM open?
Old Dec 2, 2018 | 09:38 PM
Jake87fc's Avatar
will the s4 6 pin test connector throw codes even if it has an s5 ecu? The afm is plugged in and i havent tried holding it open. I havent had time to work on the car this weekend but as soon as i can ill try all these things and maybe see if i can make a tester
Old Dec 3, 2018 | 05:18 PM
FC3S Pro v2.0:&nbsp How-To - Zenki FC3S Error Codes
Read this write-up. It's pretty straight forward.
Yes S5 ECU will send codes to the right connector in s4 chassis/wiring. Unless it was omitted in when it was wired up at the ECU.
Old Dec 12, 2018 | 07:31 PM
Jake87fc's Avatar
i couldnt find a local source to buy led lights from, but i used a volt meter to check for voltage at the b/w wire and it had 12v. and with key to on, none of the other wires had power to them. If im correct they should have voltage at dcc1 and dcc2 for the first 3 seconds the key has been put in the on position.
I didnt ground anything like you would on an s5 chassis, but i did the s4 procedure.
if for whatever reason i did everything right and theres no codes being sent to the check connector, how can i check for ecu trouble codes? Could i get them straight from the ecu somehow?
Old Dec 12, 2018 | 08:17 PM
Jake87fc's Avatar
Ecu pin 2Q or 2P or something?
Old Dec 13, 2018 | 03:32 PM
  #47
BrapMobile's Avatar
Pull your CAS out with the pulley timing marks in the correct position and make sure the markings on the CAS are lined up. From your photos your timing looks way off
Old Dec 14, 2018 | 03:43 PM
  #48
Ebay is a click away. You're gonna have a hard time fetching codes with a meter. If anything you would need two analog meters hooked up at the same time, unless the digimeters react fast enough to observe a single pulse.
The error codes are sent to DCC1 and DCC2 at the same time if I'm not mistaken.
The orange wire in the green two pin connector must be grounded to fetch codes. You won't need to do the key thing.
Old Dec 15, 2018 | 08:38 PM
  #49
BrapMobile's Avatar
Dude something internally is not right. If you lined up the CAS and timing marks and adjustment nut goes all the way to the right when you stabbed it in something is way off.
The adjustment nut should more or less be in the middle.
Old Dec 17, 2018 | 07:34 AM
  #50
Jake87fc's Avatar
I made a better line so this is it perfectly lined up. Now im just waiting on a test light
