BBS Vert wheel question.
Old Jun 9, 2004 | 10:23 AM
AlmostRice's Avatar
I have a 1990 vert that needs new tires. I have searched and have not found the answer to my question.
What type of valve stem do we need on the rim? Would just a regular metal stem do? Or are we not supposed to replace the stem?
I know the 2 of the stem caps are original, 1 missing , and 1 aftermarket. I guess I am going to remove the stem caps and center caps off before taking her in for the tires.
BTW, I am getting 4 Yokohama Avid H4S tires from Discount Tires.
Old Jun 9, 2004 | 02:08 PM
REFLUX's Avatar
www.v8less.com
I believe the tire mounting places will have valve stems for you
if you can, get metal ones but not a big deal if it's only going to be used on the street
Old Jun 9, 2004 | 02:39 PM
ZoomZoomH's Avatar
well you might as well take off the nice BBS stem caps and let the tire shop put on new stems with cheap plastic stem caps
I'm missing 1 of my BBS caps
Old Jun 9, 2004 | 02:40 PM
ZoomZoomH's Avatar
and i believe any type of stem valve will work for the vert rims.
Old Jun 9, 2004 | 04:35 PM
AlmostRice's Avatar
Thats what I thought, but I wanted to make sure. I probably will pay extra for the metal valve stems.
AR
jza80
Aug 12, 2015 11:10 PM
