BBS vert wheels on 1st gen with big brake kit
Old Aug 26, 2012 | 09:41 PM
KansasCityREPU's Avatar
Out In the Barn
Does anyone know if vert BBS wheels will fit a first gen with an Re-Speed big brake fit 5 lug conversion? I was hoping they wouldn't rub. I found a good price on a set of BBS vert wheels and would like to get them. I already have the big brale kit but have not installed it yet and need to order the MOSER 5 lug axels from Re-Speed.
Old Aug 26, 2012 | 10:00 PM
Keeble's Avatar
not too sure if he had to use a spacer or not but here you go
https://www.rx7club.com/build-thread...t-more-995958/
Old Aug 27, 2012 | 01:17 AM
Eric Peters's Avatar
I looked up those rims because i was curious what they looked like i bet those will look sweet on a 1st gen if you do end up getting them to fit post pics please
Old Aug 27, 2012 | 08:08 AM
82transam's Avatar
Never Follow
You will need a spacer, but yes they fit very well. You'll need a 25mm spacer for the fronts to not rub (FC wheels are a 40mm offset, FB's are ~15mm...). The rear will not rub without a spacer but will look "sunken" compared to the front, so I run a 20mm spacer in the back. A very slight fender roll and no rubbing issues at all.
Old Aug 27, 2012 | 08:33 AM
Out In the Barn
Thanks 82transam. I like the look. I can pick the wheels up for $100 without centers.
Old Aug 27, 2012 | 11:39 AM
82transam's Avatar
Never Follow
That's a good price, mine were $200 with the center caps and cap removal tool. They go very nicely on a FB I think.
Old Jan 21, 2013 | 06:17 PM
DreamInRotary's Avatar
Always Wanting to Learn
Little bit of a dig up but I've been researching this after reviewing your subframe swap 82trans, thanks guys
astrum
24
Nov 15, 2017 08:44 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
Marty RE
Aug 13, 2015 11:19 AM
jza80
Aug 12, 2015 11:10 PM
