BBS Vert Wheel Fitment?
Old Feb 13, 2009 | 07:26 PM
sa22c[est. 1979]'s Avatar
Resident N00b
Hello there all, I'm in the process of starting my TII 5lug swap, and I had just came across a full set of bbs verts from a friend of mine for free!(yay!). My main question is, will the bbs verts fit a 1st gen without rubbing on the suspension components? Also I plan on rolling the fenders a lot, so fender rubbing is not an issue. Also does anyone have a picture of bbs verts on a 1st gen? That'd be awsome. Thanks in advance!
-Mike
Old Feb 13, 2009 | 08:44 PM
82transam's Avatar
Never Follow
You will need 25mm spacers up front to keep them from rubbing on the springs, otherwise they fit and look great. Attached is a pic of my T2 83.
Old Feb 13, 2009 | 11:32 PM
Cmdpapichulo's Avatar
PA
82transam that 7 looks sweet
Old Feb 14, 2009 | 09:31 AM
82transam's Avatar
Never Follow
Thanks!
Old Feb 14, 2009 | 10:27 AM
thunkrd's Avatar
i'm a poser
hey transam, which springs do you have on that car?
Old Feb 15, 2009 | 09:46 AM
82transam's Avatar
Never Follow
Eibach in the rear and re-speed coilovers in the front with 200lb springs. Although I'm thinking about changing a few things on this car before spring so its thats not written in stone
Old Apr 5, 2011 | 08:40 PM
turbo_dave's Avatar
#turbodavebuilt
This is my old fb on vert wheels,from what I can remember It had a 25mm spacers up front.
Old Apr 5, 2011 | 10:03 PM
85TIIDEVIL's Avatar
ALLROTOR
Them rims look sweet on a 1st gen.
Old Apr 6, 2011 | 07:20 AM
82transam's Avatar
Never Follow
Yeah they do fit it quite well. A bunch of things have changed on my car since the pic earlier in this thread, one thing you guys might want to consider is spacing the rear's out a bit too. You need 25mm up front to clear the springs and this makes the front noticably wider than the rear. I ended up using a 20mm spacer in the rear with longer studs. So far no issues, although they do rub on some bumps, will need to roll the fender lip a bit.
Old Apr 6, 2011 | 10:01 AM
gamble302's Avatar
roadkill hats rock
what tire sizes were you able to fit on em out of curiosity?
Old Apr 6, 2011 | 01:45 PM
Jibaro 12A's Avatar
searching...
vert wheels look awesome on FB's!
Old Apr 6, 2011 | 02:00 PM
82transam's Avatar
Never Follow
They're nice and light too! I'm runing 205/50-15's (which seems to be the typical 15" tire size on a FB) on mine, you can go much wider in the back, but the front is pretty tight. Might be able to get 215's on there, but I can't say 100%
astrum
24
Nov 15, 2017 08:44 AM
diabolical1
30
Jan 30, 2016 05:50 AM
jza80
Aug 12, 2015 11:10 PM
