TO4R Finally Finished...lots of (huge) pics...not 56k friendly!!!
Ok so it is done. The car went under the knife two weeks ago today and was started for the first time today. I built this kit myself and did all the work other than downpipe in my garage. I don't have an air filter yet (ordered it last week, should be here tomm or monday). Car is not yet tuned, going to Rotorsports Racing next week.
Here are the specs of my kit...
-Garrett TO4R with .84 A/R and P-Trim Wheel (fully divided)
-Polished Comressor Housing
-HPC Coated Turbine Housing
-V-Band Discharge
-Wet Center Section
-HKS Cast Manifold (divided)
-HKS 50mm Racing Wastegate
-HKS Racing Bypass Valve
-Wastegate Dumped to Atmosphere
And now for the pictures...well some of them....the rest can be viewed at...
http://m-psphotos.fotopic.net/show_c...n.php?id=91606
Before
Manifold and Wastegate
Turbo-Compressor Side
Turbo-Turbine Side (V-Band Welded)
Turbo-Turbine Housing Inlet
Manifold and Wastegate Mounted
Turbo Mounted
Downpipe and Dump Tube On
Complete
-V-Band Discharge
-Wet Center Section
Before
Turbo Mounted
Complete
Originally posted by RX-8
hows it feel? power wise
Originally posted by spoolin
where and how much for the turbo? do you have exact dimensions on the comp wheel?
These are great people to work with. The turbo costs 950, then the polishing is 60, then HPS is 60, then V-Band welding is 40, then V-Band Discharge kit is 115, and wet center section is 75. So the turbo all came out to be about 1300 and I had it in about two weeks after I ordered it. They also have TO4S, TO4E, T66, etc.
The turbo has a 66.5mm inducer, 102mm inlet, and .70 A/R Compressor Housing. Hope that answers your questoin.
M-P
Trending Topics
Re: TO4R Finally Finished...lots of (huge) pics...not 56k friendly!!!
Originally posted by 82streetracer
what turbo manifold is that?
Well I got the HKS Manifold Part No. off of there website and gave it to a shop who sells HKS parts (not FD parts but they can get them). A week later I had my manifold, divided.
M-P
M-P
looks good. Me and garrett just put our motors in last week. still breaking mine in. i went for a 2 hour drive tonight, everything feels smooth as butter. Hey man your from hickory. another single in NC. We should definately meet up.
Jay
Jay
Alright just got the pics taken of the Airfilter installed. It is an S&B Power Stack Filter, 4" Inlet, 6" Length. Mounted on a 4" steel elbow that I also cut today. Filter is a little larger than expected. I should have no flow issues.
MP, the car looks beautiful. I highly recommend RotorSports, however they do not have a dyno to tune your car. I'm not sure if there is even a dyno close to them as they are a bit out in the sticks. If they will be dyno tuning the car, i would recommend bringing the car to www.undergroundracing.com in Charlotte, NC. If they are going to tune the car on the road, then nevermind
Darril
Darril
What they are planning on doing right now is tuning it on the road and are going to put together a big dyno tuning day for some 7's and then going to fine tune it then. They haven't decided when this day will be. But yea, Brian and Rusty at Rotorsports are great guys. They tuned it when I put the 1600's in and went nonsequential in May.
Thanks for the website on that dyno place.
M-P
M-P
Agreed. Rusty and Brian are upstanding people. The shop is really in the sticks. I wonder if they can safely stretch your cars legs when tuning it. Best of luck and please keep us updated on the tuning.
Darril
Darril
Darril
Darril
Yeah, I've been dealing with Bryan for around 2 years now. He's helped me out in when my car has been at its worst. Usually after I've had my hands on it.
I think I'll contact him about dyno day and we can compare and contrast between the different set-ups.
Well I just picked it up from being tuned today and all I can say is....best thing to ever happen to the car. I was hoping for 15 psi, but it seems that since my motor is not doing well on compression (60psi average on front, 68psi average on back) that it won't boost past 13psi. Although it does have full 12-13 psi before 4000 rpm and has 8psi by 3300 or so. I am getting the mazdaspeed team support guy next month, so I will be able to buy my motor and build it (street port) for relatively cheap for this summer, then hit a good 16-17 psi.
It should be dyno'd in the next few weeks. Possibly a dyno day with Rotorsports Racing and some other people from NC with single turbos.
M-P
M-P
Originally posted by Infini IV
Just curious if the HKS cast divided cost the same as the collected?
Here is what I got off the website:
17141-130327 MAZDA RX-7 1993-1996 Turbo ; Engine Code: 13B REW - Fits Standard or Racing Wastegate
Originally posted by RETed
Why is there a notch cut into the divider in the manifold???
M-P
Keep us posted on the numbers.
