Microtech WAT error
Old May 15, 2012 | 09:46 PM
TurboMazdaSpeed's Avatar
1.3L piston eater
WAT error
Microtechs troubleshooting guide is not available anymore dammit
What does the WAT error stand for? I recall long ago reading it could be the water temp sensor.. I just went over all the wiring for it and its fine, could the sensor be gone? The temp still reads on the DASH unit which is odd.. hence why im not sure if its the Water temp sens.
Ive been having a intermittent problem (horrendously rich idleing / stalls and dies / floods so bad needs to be push started) Last time it stalled on me / flooded after cranking and no go on the start i got WAT/REF/RPM Errors.
HELP!!
Old May 16, 2012 | 09:39 PM
bumpstart's Avatar
talking head
coolant temp went over 100 C ( off scale ) or maybe under scale cold ,, ,,hold down mode button for 3 secs to reset
most of the time the coolant sensor plastic top will be loose/ seperated and likely you have intermitant connection
befarrer
15
May 19, 2022 10:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
ZacMan
Sep 19, 2015 09:20 PM
scissorhands
Sep 16, 2015 01:25 PM
