powerd by max hood vent spacer?
Old May 15, 2012 | 05:35 AM
joegallo13b's Avatar
NY powerd by max hood vent spacer?
does anyone know if these powerd by max hood vent spacers will fit an fc?
http://www.gtfactory.jp/cms/page.php?16
1.25 thread
thanks
Old May 15, 2012 | 10:44 AM
magus2222's Avatar
On the fasttrack!
dont do it, it makes your car look broken, and really dont help with underhood temps
Lloyd
Old May 15, 2012 | 11:40 AM
Nick_d_TII's Avatar
http://www.importtuner.com/tech/impp...jdm_hood_prop/
I know it's import tuner, but seems they did back to back testing with and without.
Old May 15, 2012 | 11:59 AM
magus2222's Avatar
On the fasttrack!
well, 2 things.
1) wrong section
2) you want heat soak reduction and under hood temp reduction? its called wrap, or ceramic coat, the exhaust, as well as the intake. done
Lloyd
Old May 15, 2012 | 12:05 PM
stevensimon's Avatar
also. that is a lot of money when you can do the same thing with a stack of washers for under a buck.
Old May 15, 2012 | 07:13 PM
AGreen's Avatar
Trunk Ornament
Yeah, but those are mad billet tyte
yo.
Those numbers are hard to argue with. I agree it looks stupid, and your car will appear broken, but I may be experimenting with this myself using some datalogs. Washers and longer bolts, obviously. I've got better things to spend $30 on.
Old May 16, 2012 | 09:35 AM
CobraStngSVT's Avatar
Team SR
I used washers for my 1st gen SCCA car and saw an average temp. drop of about 15 degrees. Just FYI... and yes $30 is a lot of money for a billet part that costs maybe $3 to make. Much more reasonable at $15-20/pair I think.
Old May 16, 2012 | 09:05 PM
Rotary_Knight's Avatar
Spacers like that don't work very well to raise the hood of the FC, or washers for that matter. A good friend of mine, junpower on the forum, used to make sheet metal spacers he would bend to lift the hood up. It's because the hinges on the FC are angled inward, rather than facing up (or down). Without a picture it's hard to tell you, but I hope this helps.
Old May 16, 2012 | 11:52 PM
^ i know what you mean. when i pop and raise the hood, the hinges and hood shift a little. but does anyone know if they will fit and work? same bolt thread?
Old May 17, 2012 | 10:43 AM
AGreen's Avatar
Trunk Ornament
If the bolts don't work, you can get the right ones from hardware or parts store.
Old May 17, 2012 | 11:59 AM
seventh_rx's Avatar
Memento Mori
Lol @ the skyline with the bass boat paintjob
