changing fuel filter
Old Jul 25, 2002 | 10:56 PM
Radien Black's Avatar
Talking changing fuel filter
before i start this task does anyone know how to change the fuel filter you know the stupid guy sh*&
LIKE WHERE IS IT ...
Old Jul 25, 2002 | 11:14 PM
Silkworm's Avatar
Has been.. hangin' around
look just to the inside and just below the brake master cylinder, that black thing on the very bottom of the firewall (just under the steering gear)
easier to get to it from underneath. Still a PITA
PaulC
Old Jul 26, 2002 | 12:02 AM
Icemark's Avatar
yeah easier to get from underneith.
Unbolt the filter from the frame rail, then unclip the clamps.
make sure there is not a water heater, furnace, gas clothes drier in the area, like there is sometimes in some garages.
If the lines are really stuck and won't twist off, just cut them off as close to the filter as you can get.
have a rag handy because some gas will spill.
Once the filter is free from the lines drop it down and remove the clamp. Then attach the clamp onto the new filter and re-install it. Make sure you don't mix up the out and in on the filter when you re-install it. Out is to the engine, in is from the gas tank/rear of car.
Old Jul 26, 2002 | 12:11 AM
SilverT2's Avatar
To stop from getting gas all over you and the car, pull the egi fuse while running to let all the fuel out of the lines. Then change the filter.
Old Jul 26, 2002 | 12:35 AM
Barwick's Avatar
SCCA Rookie
Won't that screw something up? Or won't it at least flood it?
Old Jul 26, 2002 | 12:40 AM
SilverT2's Avatar
Sorry, unplug the fuel pump. and let it run.
Old Jul 26, 2002 | 12:41 AM
Icemark's Avatar
With only the few onces that spill I have never bothered to do that.
Old Jul 26, 2002 | 01:43 AM
Scott 89t2's Avatar
SOLD THE RX-7!
http://www.1300cc.com/howto/how2/fuelfilter.htm
Old Jul 26, 2002 | 03:06 AM
ryandogg's Avatar
just make sure you dont get high octane on your face. in this process.. its not a good thing to get fuel on your eyes... it feel slike pepperspray
Queppa
Nov 18, 2024 03:47 AM
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
