need a fix for stripped threads
Old Jul 25, 2002 | 03:39 PM
nimrodTT's Avatar
all aboard!
I stripped the threads on a rear wheel bolt. Threw away the bolt, but the axle threads look like toast. Priced a heli-coil at $85 and have decided an alternate solution may be best. Anyone else run into this problem before?
The threads are 12x1.50mm for anyone who wants to know. I need to install my wheel studs anyway, so maybe you can work that into the plan also.
Old Jul 25, 2002 | 03:41 PM
Keaponlaffen's Avatar
$85 for a heli-coil? That's outrageous... they're only like $45 canadian for the kit at Lordco here...
Maybe weld a bolt in? That wouldn't be too safe though...
Jeff
Old Jul 25, 2002 | 03:51 PM
MikeLMR's Avatar
'Last Minute' Rallying
Helicoil is the only way really ... unless you pull a new halfshaft from a breakers yard
Manntis's Avatar
add to cart
Sometimes if the gods smile on you it's possible to run a same-sized tap through there and force mashed threads back into shape.
A single tap (looks like a bolt with a pointed tip and 4 gouges taken out of the sides) should only cost you $2- $5 at the hardware store, but the handle (vital to spinning it straight and not damaging your threads even more) is about $15-$20.
I bought a complete tap and die set to fix stripped bolts, threads, etc for $50 CDN with a lifetime warranty.
I travel so often between LA and Saskatoon, last time I was in Cali I found myself looking in the pone book for the nearest Canadian Tire. Motomaster might be medium-grade stuff, but if the tool breaks they replace it without question & it costs about 1/2 that of Craftsman.
Old Jul 25, 2002 | 03:53 PM
have fun tapping a brake rotor, or drum... they're hardened steel, and the tap'll break, unless you get a good one...
And if you get the end of a tap stuck in something, you might as well say goodbye to the piece it's stuck in, 'cause it's almost impossible to get out, or drill out...
Jeff
Old Jul 25, 2002 | 04:00 PM
MikeLMR's Avatar
last time I checked brake rotors and drums were just plain old cast steel
not hard at all take a file to a spare one and find out
Old Jul 25, 2002 | 04:01 PM
hmmm, mine are pretty hard, then again I've never had to tap or file them therefore, I don't have a spare
But, I have turned a rotor on a lathe at school, and it was hard ****, you could only go in like .001 (one-thousandth)
Jeff
Old Jul 25, 2002 | 04:07 PM
Manntis's Avatar
add to cart
Remember, he'll only be tapping the existing hole with a same-sized tap, straightening bent threads. If the steel were that hard the threads wouldn't have mashed in the first place.
Old Jul 25, 2002 | 04:10 PM
yeah, it's just not my day... look at my other thread regarding "Guess I won't be getting my alignment and exhaust fixed..."
Jeff
MikeLMR's Avatar
I've never tried to file one but its a standardish test to see if somthings been hardened
We had a really fun time trying to drill a hole in the end of a alfa Romeo twin cam engines crank to accept a Skoda Rapide clutch release bearing ( don't ask ) that had been tufftrided ... in the end we gave up and devised a new method using a flat ground on the nose of the crank
Old Jul 25, 2002 | 04:18 PM
nimrodTT's Avatar
all aboard!
The threads are in the axle shaft not the brake rotor, I thought about threadinig it in and welding the back, but I'm not so sure, thinking I might go with drilling it out and putting in a press in stud, either way sucks because I have to remove the axle.
Old Jul 25, 2002 | 04:34 PM
REVHED's Avatar
Hunting Skylines
That's right. I cross threaded one of my rear wheel bolt threads as well (damn pesky things) so I just I ran a tap through it. It also depends on how stuffed the thread is. I got away with it because I only cross threaded it part of the way before I realised.
Old Jul 25, 2002 | 04:37 PM
REVHED's Avatar
Hunting Skylines
Comon dude. How long does it take to pull an axle? About 15mins tops.
Old Jul 25, 2002 | 10:59 PM
jeremy's Avatar
male stripper
how about mikes idea. drill and tap a more popular bolt pattern 45 degrees off the stock holes.
Old Jul 25, 2002 | 11:10 PM
Manntis's Avatar
add to cart
there's a possibility of weakening the axle flange. Why go through all that stress over one screwed up threading?
Old Jul 25, 2002 | 11:18 PM
jeremy's Avatar
male stripper
hum, lets see. maybe to be able to slect from more then 3 wheels and 2 diameters. it was mainly a joke. you would need to weld in the existing holes to add a bit of strength to that part of the radius, possibly welding some large diameter washers around the new holes to distribute the force of the stud and thicken the material up. i would think it would stand up fine as long as you weren't rallying. of course the easiest route is to upgrade to a gsl/se suspension.
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
Skeeg
Sep 5, 2015 07:41 PM
gabescanlon
Sep 5, 2015 12:04 AM
