need pics of m2 large intercooler
Old Jul 25, 2002 | 01:10 PM
Kahren's Avatar
i am not a girl
does anyone have any pictures of the m2 intercooler installed on the car, i need to see if i get a diff batery like a honda crx one that is only 5 inchs wide and make a custom mount for it to move it toward the driver side fender more, if i will be able to fit teh m2 large intercooler. thanx
Old Jul 25, 2002 | 01:24 PM
ttpowerd's Avatar
HARRRRRRRRR
You will not, there is not enough room because you will be hitting against the driver's side headlight. Here are some pics of mine, not totally installed yet though
Old Jul 25, 2002 | 01:26 PM
ttpowerd's Avatar
HARRRRRRRRR
I'll take some pics of my battery relocation later and post them up. I think it looks really good and it is vented to the outside. I might work on the venting more depending on if it meets race regulations or not.
Old Jul 25, 2002 | 01:32 PM
Kahren's Avatar
i am not a girl
where did u put the baterry and what type did u use?
Old Jul 25, 2002 | 01:37 PM
ttpowerd's Avatar
HARRRRRRRRR
Rear passenger bin. I don't remember what the type of battery it is but I will let you know as soon as I get some pics and get home
Old Jul 25, 2002 | 01:45 PM
pomanferrari's Avatar
If you have a touring, you might want to think about relocating a smaller battery in the space on the passenger side air intake. I thought about it but liked the idea of balancing the weight of the M2 large with a battery in the trunk. So mine is bolted to the trunk floor. It's a BMW R1000 dry cell battery. Still starts up like a champ: been 2 years now.
Old Jul 25, 2002 | 01:50 PM
ttpowerd's Avatar
HARRRRRRRRR
Where the oil cooler should be but is not? Never thought about that but it might be harder than moving it to the trunk. Mine was really easy to do.
Old Jul 25, 2002 | 04:01 PM
The battery will *not* fit under the hood, regardless of size, unless you're talking about a AA battery
Mine's in the back hatch near the sway bar. Make sure you use high quality thick gauge cable when you run it through the passenger compartment; my stereo system has never been the same since the switch...
Check the pic in my sig.
Old Jul 25, 2002 | 04:49 PM
ttpowerd's Avatar
HARRRRRRRRR
I have not gotten all my interior back in but this is what it looks like so far...
Old Jul 25, 2002 | 05:54 PM
Scorpio's Avatar
N-Tech BMK?
In that first pic from ttpowerd, it looks like there *might* be enough room for the N-Tech BMK (Battery Miniaturization Kit). I have been using mine for almost 4 years now...but I have the ASP Medium IC, not the large one.
I believe the N-Tech info says it will fit with a large IC, however.
http://www.n-tech.net/index.cfm?fuse...ake=&cat_id=12
I have some pics at:
http://www.micromanx.com/goble/rx7/batcrane.html
[IMG]
http://www.micromanx.com/goble/rx7/p.../BatCrane2.jpg[/IMG]
Good luck with the project!
jdayau
Nov 29, 2019 12:11 AM
