Haltech Installing additional temp sensors
Old Apr 6, 2012 | 12:16 PM
C. Ludwig's Avatar
www.lms-efi.com
Always have a few people asking how to add additional temp sensors to the ECU to display and log things like oil temp, fuel temp, ambient air temp, you name it. The common two-wire sensors we would use for these functions work great, but the circuit needs a pull-up added so that the sensors will output the correct 0-5V signal for the ECU to read. The built-in air temp and coolant temp circuits of the ECU have the pull-up circuits internal to the ECU. But when we want to add additional temperature circuits on the AVI channels, we need to add the pull-up externally. All you need is a 1k ohm resistor. Wire it as shown in the image below.
Old Apr 6, 2012 | 03:04 PM
RENESISFD's Avatar
Wastegate John
Thanks for posting this. I will definitely be referencing this thread in the future.
What resistor is that? Source?
John
Old Apr 6, 2012 | 05:21 PM
C. Ludwig's Avatar
www.lms-efi.com
http://www.mouser.com/ProductDetail/...aLLbO6C1IJA%3d
I like to use the aluminum cased resistors because they're not nearly as fragile as a simple ceramic resistor.
Old May 9, 2012 | 06:05 AM
hiboost's Avatar
Serbian
I was one of those people ... thanks for posting!
Snoopy FD
Dec 8, 2015 01:45 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
