Haltech haltech e6k ignitors??
Old Apr 5, 2012 | 02:45 AM
nvmarx's Avatar
hey guys i just got me a haltech e6k it has only done 1500ks has sat around and was out of a rx7 i got it from aus (im in new zealand) the p/o has it sent to haltech aus to get it tested it was all working as normal. it was abot 380usd with loom ans sensors etc.
now to my question, i have a s4 rx7 with a high comp s4 13b peripheral port hace engine in it i will be running a custom itb set up with 2x 1000cc or 2x 1600cc injectors to keep it simple (one injector per rotor) i have 4x bosch hec715 coils as i was going to go with a microtech with the x4 box but i couldnt find one cheap enuf haha. so can i run my haltech with the microtech x4 box?
http://microtechefi.com/index.php?ro...&product_id=60
Old Apr 5, 2012 | 02:47 AM
nvmarx's Avatar
oh to let you know im a carby guy efi is new to me lol
Old Apr 5, 2012 | 03:50 AM
C. Ludwig's Avatar
www.lms-efi.com
You can use any ignitor. Nissan has some 4-channel ignitors in their four and eight cylinder engines that work well. If you do a Google search for SR20DET I'm sure you'll turn up some info.
Also, I would ditch the MAP sensor all together and use TPS as the load source. It's common to setup NA engines this way. Especially with the P-Port, which will have a weak vacuum signal.
Old Apr 5, 2012 | 01:08 PM
RX200013B's Avatar
I would like more info on this aswell..
but can you use any coil with FC ignitors?
Old Apr 5, 2012 | 02:37 PM
C. Ludwig's Avatar
www.lms-efi.com
The long answer is; it depends. I have no idea what the amp rating of the FC ignitor is, or the Nissan ignitor I suggested for that matter. The coil you decide to use will have an amperage requirement. If you try to run the IGN dumb coil with a 5 amp ignitor, you'll burn down the ignitor is no time. For comparison, the IGN-1A coil has a built-in 19 amp driver. The new Haltech HPI uses a 15 amp driver. The older Bosch style drivers are only rated at 5 amps.
What coil do you want to use? That will determine what driver you should use.
Old Apr 5, 2012 | 04:39 PM
nvmarx's Avatar
thanks sir, i will do some searching and see what i can find it may be a cheeper option. in saying that i know a guy selling his microtech x4 box cheep as in 80nzd cheep would it be easer just useing this?
Old Apr 5, 2012 | 04:59 PM
nvmarx's Avatar
i found this is this completly differant or what i found some sr20det ignitors but they are super expencive where i am of this same site it is like your guys ebay to us
http://www.trademe.co.nz/Browse/List...x?id=463433647
Old Apr 6, 2012 | 12:23 PM
C. Ludwig's Avatar
www.lms-efi.com
The MSD is a CDI box. Completely different form of ignition.
Old Apr 6, 2012 | 04:31 PM
nvmarx's Avatar
i thought so so is the microtech x4 box a better option? or would you jump on www.trademe.co.nz and do a search for mr i searched ignitor but it didnt realy come up with much
Old Apr 7, 2012 | 10:41 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
You should just get a set of LS coils from your local Haltech dealer, they have their own built in Igniter, and the LS1's are proven to be able to driver over 650hp to the wheels on a 13B, if your power goal is lower than that you cant go wrong.
If your power goal is higher than 800-900hp then go with the Haltech HPI + Bosch/Haltech individual coils, this is an awesome setup that will provide plenty of spark for your setup.
Old Apr 7, 2012 | 12:38 PM
RX200013B's Avatar
can I get any wiring diagrams for wiring LS1 coils to the E6K?
Old Apr 7, 2012 | 06:49 PM
nvmarx's Avatar
i all ready have x4 bosch coils not going to but more just to have ignitors in them. can some tell me if the microtech x4 box will work and it is infact a 4 channel ignitor box????
Old Apr 8, 2012 | 10:29 AM
C. Ludwig's Avatar
www.lms-efi.com
Yes, the X4 box is a 4-channel ignitor. It will work fine for you. With the E6K, you will need to use IGN 1 to fire both leading coils (2-channels of the ignitor). IGN 2 and 3 will fire T1 and T2 respectively. You will need to set ignition mode to wastespark and falling edge. Not sure what dwell time those coils will want. I would start at 3ms and monitor the coils for heat and performance and adjust accordingly.
Old Apr 8, 2012 | 06:20 PM
nvmarx's Avatar
thank you sir
