1980 RX7 Junk Car Motor
Old Mar 26, 2012 | 11:41 AM
marksnewman's Avatar
GA 1980 RX7 Junk Car Motor
I ran across a 1980 RX7 that was in a rear end wreck. It has the complete motor and transmission. I got the carberator, AC hoses and AC bracket. Also got the center console. I am wishing now that I gotten the motor and transmission. Should I go back and get the motor? It is showing 85K miles. Also, it has pretty much everything in the front of the car still intact. I can pull parts if someone needs something.
Old Mar 26, 2012 | 11:48 AM
Redliner223's Avatar
Oldschool
Yes go back, it's always good to have some what of an overstock of parts because you'll never now what you will end up using. Also the engine could be used for another project later down the road.
Can you check and see if there is an antenna that is down and complete on the car for me please?
Old Mar 26, 2012 | 12:03 PM
DreamInRotary's Avatar
Always Wanting to Learn
Always go back. I wish time and time again that I had pulled more parts off an FB around me. Check to see if there is a dome light cover, I'm in the market for one
Old Mar 26, 2012 | 12:53 PM
I will check for both the antenna and dome light cover.
Old Mar 26, 2012 | 12:54 PM
Redliner223 are you looking for a power antenna? My car has a power antenna in the rear on the passanger side.
Old Mar 26, 2012 | 12:57 PM
Oldschool
Yes the power antenna, it should be stock for all of the rx7's.
Thanks for looking.
Old Mar 29, 2012 | 12:45 PM
Redliner223 the power antenna was damaged from the rear end collision. Sorry
lindahlish the dome light cover is not there. Sorry
I do own the engine and tranny now tho.
Old Mar 29, 2012 | 05:04 PM
Oldschool
Thanks for looking I greatly appreciate it.
Old Mar 29, 2012 | 08:39 PM
dbragg's Avatar
Say hello to Mr.Wankel
Where is GA? What color is it? Does it have a sunroof?
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
