Rotary Drag Racing The place to post your racing stories and info
What Plugs?
Old Mar 20, 2012 | 08:37 PM
RXTASY57's Avatar
Viper Eater
ID What Plugs?
Which plugs do you use?
Currently, I am using Greddy Pro Racing Plugs RE11's, but at $42 each, I am open to alternatives.
Putting down somewhere around 600 RWHP and running E85.
Any suggestions?
Old Mar 20, 2012 | 10:48 PM
sk8world's Avatar
Chasing numbers
Any suggestions?
Keep using them! Buy a plug cleaner at harbor freight and just rotate them. I buy a set or 2 each season and run them until they crack. also try buying from air, he usually prices them well but you are not going to find them much cheaper!
Are you street driving with them? I run 9's on the street, also warm up at the track On them. Then swap in the race plugs and maybe swap in another set depending on how many passes I make.
Old Mar 21, 2012 | 04:23 AM
AnthonyNYC's Avatar
Stay tuned...
I run the NGK 11.5 heat range. R6725-115.
If anyone needs a set I have a set for sale. $130 shipped.
Thanks,
Anthony
Old Mar 21, 2012 | 07:32 AM
Slammedblk7's Avatar
Yes its slow
R6725 but I believe R7420 is the newer version. I found them for 32.xx a plug.
Old Mar 21, 2012 | 09:59 AM
sk8world's Avatar
Chasing numbers
The re11 are NGK's (prettysure). Available in the same heat ranges. 10.5 thru 11.5. They all seem to be priced about the same.
Old Mar 21, 2012 | 10:36 AM
Bacon's Avatar
IRS 4 Life
the 7420's have a 21mm reach (6725 is 21.5mm)
and the 7420's are iridum, the 6725 are platnium
Old Mar 21, 2012 | 10:47 AM
Yes its slow
Sooo which is better???
Old Mar 21, 2012 | 10:52 AM
Bacon's Avatar
IRS 4 Life
IDK, But some iginitions systems specifically say "do not use platnium plugs"
Old Mar 21, 2012 | 11:22 AM
Yes its slow
I thought the "greddy" plugs were 7420s for some reason... But I'd better check M&W if it says anything about plugs... So I don't fry anything
Old Mar 21, 2012 | 11:49 AM
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
^ The Greddy plugs are the R7420 iridiums. Only difference I found was price, the Greddy's were usually cheaper. I'm also going to be trying out the NGK BUE's this summer, they are surface gap like OEM, but as cold a plug as you can get (don't list a number). Only problem with them is they are not as long in the thread area, and are a bit more recessed than stock.
Old Mar 22, 2012 | 03:39 PM
C. Ludwig's Avatar
www.lms-efi.com
Believe the Greddy RE plugs are no longer available. Not listed on the latest price sheets anyway.
Old Mar 22, 2012 | 06:03 PM
AlexG13B's Avatar
brap brap brap
is it safe to use a spark plug cleaner on the greddy plugs?
Old Mar 22, 2012 | 06:32 PM
sk8world's Avatar
Chasing numbers
I do.
Also just ordered another set of RE11's just now!
Old Mar 22, 2012 | 06:58 PM
JdmRX's Avatar
1262@54psi
Greddy re11's are just a denso iridium plugs rebadged, and you can buy the denso plugs for like 20 bucks less for the set of 4 desnso's
Old Mar 22, 2012 | 07:32 PM
AlexG13B's Avatar
brap brap brap
Wat media do u use to the blast the plugs?
Old Mar 22, 2012 | 08:53 PM
sk8world's Avatar
Chasing numbers
not sure, it came with the kit,
Old Mar 22, 2012 | 10:03 PM
You have a link to these Denso plugs?
Old Mar 23, 2012 | 09:27 AM
RXTASY57's Avatar
Viper Eater
Yes! I would like to see these as well! $40 a plug is just too much in my book.
Old Mar 23, 2012 | 10:43 AM
AlexG13B's Avatar
brap brap brap
yup, i just bought these greddy heat range 10s for like 140 for my daily. i wonder how long they gonna last :/
Old Mar 23, 2012 | 10:48 AM
sk8world's Avatar
Chasing numbers
NS
Thanks,
Anthony
$33 a plug is a good deal
Old Mar 23, 2012 | 11:54 AM
RXTASY57's Avatar
Viper Eater
Thing is, I drive my car on the streets and sometimes like to get in to 25+ PSI.
Don't want a hot plug in there if I'm going to do that.
Just bought a set of the Greddy's and have a set in there already that I will take out and clean and then swap them back and forth.
Old Mar 23, 2012 | 12:31 PM
The Greddy plugs are definitely not Denso, they're NGK, and you aren't going to find them (the R7420's) for any cheaper than the Greddy's. When I got mine I got them through RHDjapan: http://www.rhdjapan.com/trust-greddy...tary-13b-13926 for $35/plug.
You can even see on the side of the Greddy plug it says NGK Iridium.
Old Mar 23, 2012 | 07:41 PM
JdmRX's Avatar
1262@54psi
ok i thought they were denso's, I get em from sparkplugs.com Part# IRE01-32. change the number after the dash for the different heat ranges.
Old Mar 24, 2012 | 12:39 AM
The densos look almost identical to the NGK R7420's though, so maybe they are all the same plug? The Denso's are listed for more than the NGK's, check here: http://www.ngk.com/results_cross.asp?pid=7756&x=0&y=0
Old Mar 24, 2012 | 11:27 AM
jamespond24's Avatar
Autolite AR3931 for around $4 each. My friend is pushing over 800+rwhp on them on gas.
