Sponsored by: CARiD
FD rotors in FC
Old Mar 17, 2012 | 09:28 PM
audoetuk's Avatar
Exclamation FD rotors in FC
Is there anything that needs to be done to run fd rotors in an fc to be able to run the bigger apex seals?
Old Mar 17, 2012 | 09:46 PM
KNONFS's Avatar
B O R I C U A
89-91 FC turbo rotors are practically the same as the FD rotors. You can swap them without a problem. Not sure what you mean by bigger apex seals...
Old Mar 18, 2012 | 02:30 AM
audoetuk's Avatar
I have an 88 t2...I mean 3mm as oppose to 2mm
Old Mar 18, 2012 | 06:41 AM
Banzai-Racing's Avatar
Rotary Specialists
FD rotors are 2mm, they would have to be machined to use 3mm. To install FD rotors in a S4 car you also need the front and rear counterweights (or flywheel).
Old Mar 18, 2012 | 09:15 PM
audoetuk's Avatar
So what car has 3mm seals stock?
Old Mar 18, 2012 | 09:20 PM
Rxmfn7's Avatar
Do a barrel roll!
First gens came with 3mm seals. Everything pre- '86.
Old Mar 18, 2012 | 09:29 PM
audoetuk's Avatar
Aiight thank you
Old Mar 19, 2012 | 12:02 PM
RotaryEvolution's Avatar
Sharp Claws
technically the only 13B engines that had 3mm seals were the 74-78 early 13B engines from the REPU and RX4 as well as the 84-85 GSL-SE. those rotors are all 9.4:1 compression and are 3mm OE seals. as with any series rotors you need the counterweights from those original engines.
the early 3mm rotors were also the heaviest weighing in at about 11lbs each.
Old Mar 19, 2012 | 01:09 PM
Jeff20B's Avatar
Lapping = Fapping
9.2 compression on the early rotors.
Old Mar 19, 2012 | 01:58 PM
Sharp Claws
not sure i believe that quoted figure. the REPU pockets are .6mm shallower than S4 n/a rotors and the whole tube is cut smaller in diameter. the pockets actually most resemble S5 n/a rotors but the S5 are shallower yet but the recession cutout is larger.
GSL-SE rotors do conform to the more modern 2nd gen pocket design. you're probably right that the REPU/4 has a different CR but i'd have to do more measurements to agree that it is lower, the rotors themselves would have to be smaller to compensate or the radius less.
i've heard people even claim the GSL-SE rotors as 9.2:1 which is false, the cutout is identical to S4 n/a pocket design.
edit: checked the REPU rotor and it has the same radius and rotor dimensions, the recession is one of the smallest of all series to date so i have a hard time believing it is a 9.2:1 with the dimensions i checked against other rotors. the tochoidal face of the housings is also identical to newer housings so it wasn't lost there.
i'd almost believe they were 10:1 rotors by staring at them and comparing versus all the other rotors, the main difference is the edges slant sharply, giving it a little more volume there.
Old Mar 19, 2012 | 02:46 PM
Jeff20B's Avatar
Lapping = Fapping
It's generally accepted, but could be incorrect. I was going with what Mazdatrix and Dave Atkins said. I've never actually measured them myself. Sorry I parroted there.
jase03
26
Sep 29, 2015 10:36 AM
20B Forum
Sep 22, 2015 07:39 PM
ZacMan
Sep 19, 2015 09:20 PM
Ian_D
Sep 6, 2015 10:38 PM
