New FD Wilwood BBK?
Old Mar 11, 2012 | 09:42 AM
moehler's Avatar
NJ New FD Wilwood BBK?
If it's not new, it's certainly new to me .
http://wilwood.com/BrakeKits/BrakeKi...l=RX-7&option=
It looks pretty nice, the rotors are slightly smaller than RB, Stoptech, and Brembo, but for the price ($1675 new) it looks like it's a good kit. Has anyone seen this yet, or have any experience with it? What do you guys think?
Old Mar 11, 2012 | 10:32 AM
amp's Avatar
amp
old yella
looks like a nice alternative... wonderin if the .80 clearance works with fikse fm5s..
Old Mar 12, 2012 | 11:06 PM
DriftDreamzSS's Avatar
My Fd was almost used for test fitting that kit but I was out of town so another local FD owner got hooked up. Last I heard he was still doing some work on the car so im not sure if he has had a chance to test them out much yet to give any feedback. They do look really nice tho and ive always been impressed with the quality of wilwood products.
Old Apr 7, 2012 | 07:22 AM
lane_change's Avatar
It has begun
Anyone know anything more about these brakes?
Old Apr 7, 2012 | 12:05 PM
BLACK MAMBA's Avatar
FD Project
Summit racing has same part number 1494.00
http://www.summitracing.com/parts/WIL-140-11963
Old Apr 7, 2012 | 08:02 PM
It has begun
Now I just need to know if people think these are worth a damn. Don't want an OEM replacement BBK.
Old Apr 7, 2012 | 08:06 PM
amp's Avatar
amp
old yella
if these are anything like the old m2 brake kit... definitely an improvement over stockers with hawk blues at the track..
if recallin correctly.. m2 used the same six piston wilwood calipers.. theres a set for sale here
Old Apr 8, 2012 | 01:57 PM
mannykiller's Avatar
Garage Hero
I'm waiting for the sake bomb garage kit. Ap racing = win
Old Apr 9, 2012 | 03:08 PM
It has begun
How much are they planning to charge for that AP Racing kit? Any idea on the weight?
Old Apr 10, 2012 | 01:54 PM
Smokey The Talon's Avatar
Long time on-looker
Great kit for the price. I have the old old M2 version of this kit which has an older rotor hat design and the Willwood Superlite 2A calipers (2 piston). I've been very happy with it, and I'm using a 929 master cylinder with it.
Old May 22, 2012 | 08:12 AM
BeanieTec's Avatar
I'll be the guinea pig and try these out, they look nice and the price is right. I'm not looking to go 14 inch rotors or track the car really either. I'd go with the SakeBomb street kit if it destroys these, once we get some info on it
Mike
Old May 22, 2012 | 11:05 AM
moehler's Avatar
Mike
Awesome. I'm probably gonna pull the trigger on these too. Between the good tech info, the shallow caliper offset, and the great price, these keep looking better and better. I wouldn't worry about destroying these, but I am curious about brake bias with them. Their average piston size looks good for a 6 piston caliper, so I think it will be fine, but am not sure. Really the only big difference I see between these and other kits currently out there is the rotor thickness is about 1/8" inch less. I'm sure it makes a difference, but it can't be that dramatic.
Old May 22, 2012 | 09:31 PM
BeanieTec's Avatar
I need to come up with something for the rears as well. Maybe 99 spec setup? I don't believe Wilwood makes a rear set. I have seen a rear setup by Rotora with 4 piston calipers for a reasonable price, but I'm wondering if that's overkill.
Old Oct 16, 2012 | 02:06 PM
Farkel's Avatar
A N T I H E R O
From: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
Bumping this up to see if anyone has bought this BBK. Any real world experiences or possibly comparisons? I see Wilwood also has a larger 14" version of this BBK.
Old Oct 16, 2012 | 08:19 PM
Long time on-looker
As I mentioned above I have the older version of this kit. I just got back from a weekend at Mid-Ohio where I would regularly stop from 140-ish on the back straight without trouble.
I use Hawk HT-10 pads front and rear (stock rear with just upgraded rotors). I also use Motul RBF600 fluid which is important.
Old Nov 20, 2012 | 02:35 AM
alpinaturbo's Avatar
They fit under 17" wheels?
Looking to stick to smaller wheel diameter, 17's.
Old Nov 20, 2012 | 02:41 AM
Exidous's Avatar
The Stoptech's 13"ers fit under a 17" wheel so these should be fine as well. MAYBE even under a 16". Depends on the caliper.
Old Nov 21, 2012 | 07:34 AM
Long time on-looker
Mine fit fine under a set of 17x8.5 SSR Comp wheels
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
04G35S
Sep 9, 2015 07:05 AM
