possibly bad 12a, what do u think?
Old Jul 23, 2002 | 06:31 PM
krackerx7's Avatar
possibly fuct 12a, what do u think?
got a free SA im told it was blown. but want to find out my self but would have to get some ignition stuff. but i pulled the trailing plugs and turned it over by hand and oil came out the spark-plug holes.... any chance of this thing running w/o a complete re-build? otherwise im just gonna pull it apart for *****. thanx.
Old Jul 23, 2002 | 10:42 PM
oil outta the plug holes.... probably shot.. but i don't know jack, just a warning
Old Jul 23, 2002 | 11:55 PM
jeremy's Avatar
male stripper
yeh, oil out of the plugs holes is generally a bad thing. for ***** you could fire it up though and see how bad it smokes. what are you going to do, tear it up?
Old Jul 24, 2002 | 12:52 AM
Jeff20B's Avatar
Lapping = Fapping
Was it stalled in oil for storage reasons? Probably not. Try to fire it up anyway.
Old Jul 24, 2002 | 01:05 AM
diabolical1's Avatar
i think you should mail it to me ...
Old Jul 24, 2002 | 08:52 AM
damon's Avatar
usually means that the oil retaining rings are gone, unless as previously mentioned it was stored in atf or oil
peace
Old Jul 24, 2002 | 09:52 AM
AdamAnt's Avatar
FUBAR!!!!!!
Old Jul 24, 2002 | 03:48 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
How much oil? The rotor oil control rings are probally shot, unless someone put somehting in the carb/motor to increase compression. Or to allow it to set for some time without running... Purge it really good with gas and see if the oil stops coming outta the holes. If it does and has decent compression you might get some miles outta it. If oil is coming out of it all the time then a rebuild will be neccessary, unless you like perpetual oil changes and smoking like a coal burning freight train
Old Jul 24, 2002 | 04:22 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Re: possibly fuct 12a, what do u think?
Originally posted by krackerx7
...i pulled the trailing plugs and turned it over by hand and oil came out the spark-plug holes...
Unless there's about four gallons of oil in the engine, I'm inclined to think that someone had tried to soak it in MMO or ATF.
If the seals were so damn shot, then the oil would drain back down to the pan.
No?
If it's filled w/oil and you flush it w/ fuel, be prepared for a fire at the exhaust side of the engine when it starts.
Old Jul 24, 2002 | 05:55 PM
MIKE-P-28's Avatar
Re: Re: possibly fuct 12a, what do u think?
No?
I was meaning leave the exhaust off and let it flush out in a bucket or oil drain pan..
Common sense would tell you to wash the bay down really well with water and degreaser before ever attempting to start and run it with raw fuel on there.. Im sorry I left common sense stuff of the topic
rgordon1979
40
Mar 15, 2022 12:04 PM
Frisky Arab
Sep 4, 2015 06:17 PM
