Would a single 38mm wastegate be to small
Old Mar 7, 2012 | 10:17 AM
TOYOROTOR's Avatar
i plan to run very low boost on my 13b old school 4port setup with a blow-thru sidedraft. looking
for only 8-10 psi. will a single 38mm Tail wastegate be to small causing boost creep?
Old Mar 7, 2012 | 02:59 PM
drifting in drifting's Avatar
Depands on what turbo you plan on running plus what manifold
Old Mar 7, 2012 | 03:33 PM
TOYOROTOR's Avatar
T3/T4 hybrid turbo, and custom made manifold. This setup is going into a corolla.
Old Mar 7, 2012 | 03:48 PM
Should as long as you dont go to big with the turbo i had mad creep with a 38mm on a to4s.
Old Mar 7, 2012 | 03:54 PM
RotaryRX-007's Avatar
38 is probably fine if the plumbing is well thought out.
IIRC, 34mm is what BNR ports out stock s4 housings to on their stage 3 upgrade.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Ian_D
Oct 14, 2015 12:31 PM
