Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
question on building an shallow oil pan.
Old Mar 4, 2012 | 08:09 PM
86PICKUPSTICKS103's Avatar
GA question on building an shallow oil pan.
if i take an get me a factory oil pan an cut it 1.5 inchs all the way around an shallow the pic up the same would the motor be ok. i understand it would be less oil capasity but ill just change it more often?
any insight on this would be great. thanks
Old Mar 4, 2012 | 10:18 PM
diabolical1's Avatar
Originally Posted by 86PICKUPSTICKS103
i understand it would be less oil capacity but ill just change it more often?
cooling will likely be affected by decreased capacity as well and i think that's more important.
Old Mar 5, 2012 | 08:08 AM
fidelity101's Avatar
Rallye RX7
just curious... but why?
The pan sits above the the cross member anyways, what kind of project you got going on that you need to do this?
also I know it costs a lot but you can always go dry sump
Old Mar 5, 2012 | 10:22 AM
Well I have a 70 bug an the oil pan sits low an everytime I pull off hard in the car it hits I've raised it up now I need it shorter
Old Mar 5, 2012 | 01:56 PM
Rallye RX7
ahh okay, that would make more sense.
Old Mar 5, 2012 | 02:03 PM
j9fd3s's Avatar
Community Builder
if you make the pan shallower, i would add another oil cooler, or something to keep the oil capacity.
it should be ok, the Rx8 has a really shallow pan, and 2 big coolers
Old Mar 5, 2012 | 05:58 PM
Would a rx8 oil pan bolt up on a 12a?
Old Mar 5, 2012 | 10:40 PM
j9fd3s's Avatar
Community Builder
its going to be too long, although the width is right, and some of the bolt holes will line up
Old Mar 6, 2012 | 09:04 AM
Dang that would havea been great
Old Mar 6, 2012 | 09:48 AM
Rallye RX7
you can always hack up an extra oil pan you got laying around and see. Its gotta take a half hour to remove the engine from that thing I imagine.
Old Mar 6, 2012 | 02:58 PM
Pettersen's Avatar
What if you just widen the oilpan, that way you keep the capasity. But space might be an issue?
FD7KiD
15
Feb 26, 2021 10:12 PM
astrum
24
Nov 15, 2017 08:44 AM
FD7KiD
Aug 17, 2015 11:50 PM
