Megasquirt Problems with MS2; losing sync?
Old Mar 4, 2012 | 06:24 PM
jsnow82's Avatar
Hi everyone and thank you very much for checking out this thread and helping. Im having a problem ever since I went from MS1 to MS2. At about 5500 rpms im losing sync on the higher resolution signal(s4 TII unmodded cas). It works fine all the way up to 5500 and starts acting up, I can watch the rpms glitch on the tach as well as on the tunerstudio. I installed new plugs and wires thinking it may just be misfiring, still the same. I also installed a timing light on leading and trailing wires and it would blink when the rpm glitch occured. I have re grounded the MS to a seperated ground and installed several ground straps to take out the noise, if that was the issue. Car is still acting up. All was good up until I changed from MS1 to MS2
Any help is greatly appreciated, Im all in. Im so frustrated to the point of getting a different ecu and having a tuner dial the car in. I have MS for several years.
Thank You,
Jose Nieves
Old Mar 6, 2012 | 02:15 PM
muythaibxr's Avatar
MegaSquirt Mod
Please post your settings, configuration of your tach input, etc..
Ken
Old Mar 6, 2012 | 02:29 PM
jsnow82's Avatar
Do you mean post an msq? If so how do i do that?
Old Mar 24, 2012 | 04:52 PM
jsnow82's Avatar
So i was looking thru a recent datalog and notice loss sync 17 in a couple areas. one at about 2000rpms, and really bad at 5500rpms to the point of not being able to boost. Any ideas?
Old Mar 25, 2012 | 03:30 AM
.::evil inside::.'s Avatar
what spark plugs are you using? Stabbed CAS or utilising both wheels? As Ken said, msq may speak volumes...
Old Mar 25, 2012 | 09:43 PM
jsnow82's Avatar
I dont know how to post an msq, can someone tell me? Id be happy to do so. I am utilizing both wheels and the cas is stabbed. Im running ngk 7420-10&10.5 plugs. Prior to that i ran regular plus and it still did the same thing. This all started to happen after switchin to ms2 from ms1. It ran very well on ms1.
Old Mar 26, 2012 | 10:33 AM
muythaibxr's Avatar
MegaSquirt Mod
You can zip it and then attach it to a post.
I need to see that to see if you have everything configured correctly for the rx7's inputs.
Ken
Old Apr 19, 2012 | 08:42 PM
jsnow82's Avatar
Ok so after debating i finally installed my FFE crank trigger kit. Instsll was smooth and it started right up. I kept getting sync loss 2 codes. I tried adjusting my r52+r56 pots. Still did it. I run shielded cables and regrounded everything. Only way i got rid of it was by running the noise filter. Now under wot in boost its feels like it misses and revs past the miss no sync loss, funny thing, thats what it feels like. Ill post an msq and datatog.
freddyrx3
Rotary Drag Racing
31
Mar 9, 2019 08:32 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
