Drifting Discuss Drifting and drifting techniques here.
no rear sway?
Old Mar 4, 2012 | 03:09 PM
truebluegallo's Avatar
no rear sway?
anyone running no rear swap?i have 8kg rear spring rate so im thinking id be fine right?
Old Mar 4, 2012 | 03:42 PM
K!NCH's Avatar
Street yes, track no.
Old Mar 4, 2012 | 05:18 PM
I fc3SLIDE's Avatar
alot of people that drift fc's run no rear sway it helps with the snappiness while transitioning imo
Old Mar 4, 2012 | 06:37 PM
Vell's Avatar
If you want more mechanical traction, do it !
Old Mar 4, 2012 | 08:07 PM
so ur saying sway on track???
Old Mar 5, 2012 | 01:56 AM
K!NCH's Avatar
No I run the sway on the street, and I disconnect one link and disable it at the track.
Old Mar 5, 2012 | 04:50 AM
ive been driving on it today i feel like its hard to breakloose feels like it just wants to grip an corner hard am i tripping?
Old Mar 6, 2012 | 03:36 PM
Any input?
Old Mar 6, 2012 | 04:20 PM
TweakGames's Avatar
FD pro licensed driver
Like said earlier, disconnecting or removing your rear sway bar will make the rear softer and thus give more traction. If you are a herp derp NA rotary, put it back on, and get off the track.
Old Mar 6, 2012 | 04:33 PM
rx7w/yaw's Avatar
Stay Into It!
Nope sounds about right. Just push the rear out harder (ie clutch kick) and the rear will smoothly slide out rather than snap out. Since I dropped the rear sway I can actually manji because it doesn't snap the other direction. Its more grip for a smoother slide.
Old Mar 6, 2012 | 04:47 PM
ilia's Avatar
Chicago
Old Mar 7, 2012 | 04:40 AM
im a herp derp na hahaha s4 >:[ sway goes back on tomorrow
Old Mar 7, 2012 | 05:17 PM
airquin23's Avatar
Team U.R.S
NA here. No rear sway bar on the street or the track. It's fine for me. I'v been driving like that forever now. Feels awesome.
Old Mar 7, 2012 | 08:27 PM
bewst12psi's Avatar
My car is green
Originally Posted by airquin23
Feels awesome.
So does sex w/o a condom .... live wreckless
Old Mar 7, 2012 | 09:00 PM
Hayseed7's Avatar
Old Mar 7, 2012 | 09:26 PM
airquin23's Avatar
Team U.R.S
Wreckless Na. Lazy Ya. Don't want to keep putting it on then connecting again blah blah blah. It's also the same reason I'm on the bottom during sex.
Old Mar 8, 2012 | 07:59 PM
leftcoastdrifter's Avatar
Dustin Becktold
I run swaybar-less, front and rear, everywhere. Streets and track, feels a lot more controllable on the track and I don't even notice it anymore on the streets.
And it's more like sex with your wife, you know it's safe cause she's already been tested.
Old Mar 9, 2012 | 12:02 AM
rx7w/yaw's Avatar
Stay Into It!
Originally Posted by leftcoastdrifter
i run swaybar-less, front and rear, everywhere. Streets and track, feels a lot more controllable on the track and i don't even notice it anymore on the streets.
+1
Old Mar 9, 2012 | 02:41 PM
ruddyrid's Avatar
Doin' Work Son!
Wait i have a question. I have helper springs in the rear and i find it real hard to transition without having to correct my speed a bit with the ebrake.
Since the helper springs add a lot more droop, would it benefit me to run one??? I used to have a TII front sway(24mm?) i now put on a 22mm NA sway bar up front and feels way better, especially considering i have a carb set up whit no electronics. So this makes it way lighter than a TII.
I'm going drifting this weekend with this set up
Stance XR coilovers(DG-5?)
8kg spring up front
6kg rear w/ helper spring
22mm sway up front
no rear sway
no chassis reinforcement
welded diff.
Next time i go i plan on installing the rear sway
Old Mar 10, 2012 | 12:32 PM
TweakGames's Avatar
Lol, helper spring.
MazdaAspec
Sep 9, 2015 02:04 PM
