Drifting Discuss Drifting and drifting techniques here.
diff welding write ups??
Old Feb 28, 2012 | 05:34 AM
truebluegallo's Avatar
anyone know if theres a fc diff welding how-to with pics on here??? i cant find ****
Old Feb 28, 2012 | 05:26 PM
ComicArtist's Avatar
It's pretty straightforward. Cut a steel plate to fit between the spider gears, and weld them all together. Flip the diff over, repeat.
Old Feb 28, 2012 | 10:31 PM
Tatakai's Avatar
yea i had to ask around to figure this out myself.. especially since i just tried welding the spider gears only to realize it still didnt act like a welded diff, LOL you need to weld the spiders to the casing it sits inside of. here's a picture my friend drew for me (pardon the ms paint skills)
basically i took the diff housing, put the gears/gear housings inside of it (to make sure things were lined up) tack welded the housing to the gear (outside where you see the splines) flipped it over, did the same, made sure everything fit right, and welded it up, again inside of the housing to make sure things didnt get misaligned. everything is a tight fit so i imagine if you let things get moved around you're boned and it wont fit.
basically, take the clutch discs out, and welded where the discs were.
Old Feb 28, 2012 | 10:33 PM
TweakGames's Avatar
FD pro licensed driver
l
o
l
<3s
Old Feb 28, 2012 | 10:51 PM
midnightbluefc's Avatar
lol the paint diagram is amazing! pretty you pretty much have the concept down good luck man.
i really apricieate the advice an animation lool but i need like an actual pic:/ sorry im stupid lol. can u not weld it without removing it from the housing like an s13?
Old Feb 28, 2012 | 11:20 PM
bumpstart's Avatar
talking head
our diffs are front loading banjo type so the have to come out and sit on the floor
the rear loading type of diffs like the are much more of a pain in the setup though
the trick is to leave axles in when you drop in the plate else it may drop low,,, or spatter may get into the splines
and you also have to spot weld the back of the spider shaft to the case and be sure the weld is not so high to stop it rotating in the case
PS welding is messy no matter whet due to oil the contamination
you can choose a strong mig or and arc
and using some penetrene spray ( oil based ) will help the weding process and help the spatter not to stick
hilux toyo G diff is pictured ,, our diffs are very similar inside
Old Mar 1, 2012 | 12:36 AM
so u only use oneplate an weld it? on my s13 i used two plates i welded in one then roatated the axels an did the other side
Old Mar 1, 2012 | 01:39 AM
bumpstart's Avatar
talking head
1 plate each side to lock up all the spider gears
Old Mar 6, 2012 | 05:22 PM
lever2000's Avatar
Lever 2000
I finally got a weld on my rear end haha. So is it gonna break easier with a welded rear end or something orrr any drawbacks really to this... aside the fact that it drags the other tire when turning of course.
Old Mar 9, 2012 | 10:56 PM
paganizondadude's Avatar
7LAB
Thats my paint picture!
Its easy to get the diff out and you just weld the main drive gears there the axles slide in. Its honestly not rocket science..
Old Mar 12, 2012 | 10:24 PM
ForsakenRX7's Avatar
zoom zoom go boom
If you can't weld or are just inexperienced have someone else weld it up cause proper heat penetration is important doing this. Weld fails are catastrophic.
Old Mar 19, 2012 | 09:08 PM
Spannersrx7's Avatar
I purchased an old auto diff 3.8 ratio I think that had been sitting round for years by the looks of it no axles etc. Pulled the back off it welded the spiders with an arc and haven't had any issues 3 years later of alot of track work
renjiv2
57
Jan 25, 2024 03:34 AM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
Captain Hook
13
Oct 4, 2015 06:35 PM
WANKfactor
Sep 29, 2015 01:14 PM
