Using the low fuel sender without factory harness
Old Feb 26, 2012 | 10:10 PM
danegerous's Avatar
it go down in the dm
Hey bro's, been awhile. Hope all is well. Anyway, in this new box of shenanigans I've decided to build, I'm running a bare bones harness (no lights even at this point) and I want to know if I can use the factory low fuel sensor to illuminate a light on the dash? It'd be a buttload cheaper then an aftermarket fuel gauge and since none of OHM's translate anyway, a gauge wouldn't be that accurate. Just something to light up if the levels low would be cool. Thank you for looking
If I were able to run it, would I just connect a wire to it, route it to the dash, hook it up to an LED or whatever I have lying around and that would do the trick?
Old Feb 26, 2012 | 11:04 PM
clokker's Avatar
Cake or Death?
Yes.
The sender is just a ground so put power to the light and run the other leg to the sender.
Old Feb 26, 2012 | 11:12 PM
danegerous's Avatar
You have helped me so many times Clokker. If you ever find yourself in the San Diego area, look me up. I owe you a drink or two.
Old Feb 26, 2012 | 11:35 PM
clokker's Avatar
Cake or Death?
Aw, thanks but I rarely drink.
I do have a red card though.
streetlegal?
Mar 17, 2022 02:46 PM
82streetracer
Aug 23, 2015 09:28 AM
