90. fc with idle problem (video)
Old Feb 26, 2012 | 04:05 PM
87FCna's Avatar
Stoned
MD 90. fc with idle problem (video)
https://www.youtube.com/watch?v=IPVH...e_gdata_player
it does the hole cold start. but as soon it finishes, it bounces. i pulled the plug from the throttle body. & it smooths out at cold start revs. 3500 rpms
Old Feb 26, 2012 | 04:46 PM
87FCna's Avatar
Stoned
bump. edit video
Old Feb 26, 2012 | 06:08 PM
87FCna's Avatar
Stoned
anybody ?? help
Old Feb 26, 2012 | 06:15 PM
Logicalbomb's Avatar
I wanna go fast.
Alright the first thing to check is for ANY air leaks from the throttle body to the filter box. The second thing I would check is your two adjustment points on top of the upper manifold. There should be a screw directly on top of the throttle body that allows you to adjust the throttle intake. Try adjusting that lower to see if it decreases that throttle bobble.
Old Feb 26, 2012 | 06:57 PM
87FCna's Avatar
Stoned
thanks any other suggestions?
Old Feb 26, 2012 | 07:37 PM
I wanna go fast.
TPS sensor perhaps, they go out constantly.
Old Feb 26, 2012 | 08:48 PM
SpikeDerailed's Avatar
This sh*t burns oil!
That thing is idling WAY to highfor being fully warmed up. First find the vacuum leak you have and fix that, then when you get it to idle at 750 fully warm set the narrow range tps to 1volt at the ecu.
Old Feb 27, 2012 | 02:02 AM
-RotorDemon-'s Avatar
Rotary nut for 15 years.
Check the codes and see what you find. TPS will do that, So will the IAT.
Old Feb 27, 2012 | 03:39 AM
87FCna's Avatar
Stoned
thanks guys. more info the better!
Old Feb 27, 2012 | 06:53 AM
Molotovman's Avatar
Ban Peak
Best way to check for vac leaks: Start it up and spray carb cleaner around the manifold mating surfaces and vacuum hoses. If it's sucking in unmetered air, the engine will suck in the carb cleaner at the location of the leak and speed up.
It could also be a stuck throttle plate, and is your timing correct? Did the car sit for a long time beofre you got it?
Old Feb 27, 2012 | 06:57 AM
87FCna's Avatar
Stoned
yes. it sat for awhile. the second ports are stuck also.
Old Feb 27, 2012 | 06:58 AM
87FCna's Avatar
Stoned
ill get a better video clip when i get off work.
Old Feb 27, 2012 | 09:46 AM
spahn1's Avatar
240sx guru
not sure if this helps but i had a honda that did that, it was the mapping sensor
Old Feb 27, 2012 | 01:30 PM
87FCna's Avatar
Stoned
https://www.youtube.com/watch?v=37dA...e_gdata_player
updated video!
Old Feb 27, 2012 | 01:39 PM
spahn1's Avatar
240sx guru
holy **** dude........
Old Feb 27, 2012 | 01:53 PM
Molotovman's Avatar
Ban Peak
Have you checked for vac leaks? Have you flushed the coolant?
From the video it just seems like the thermowax in your TB isn't functioning right. My car hunts like that until it's warmed up all the way.
Your throttle plates could be stuck too.
You physically need to make an attempt to work on it, taking the suggestions we've made, and tell us the results.
You keep on asking "What's wrong" and have never made a post reflecting that you've tested our suggestions. Sorry but we can't help you unless you make an attempt.
Old Feb 28, 2012 | 02:43 PM
That plug you pulled is the throttle position sensor. If the car doesnt see the tps signal it ignores it and uses the maf, map, cas, and h20 temp for timing and fueling needs. The car SHOULD NOT be idling at over 2000rpms. You have a air leak somewhere, be it metered(thermowax failed open, bavc open, aws open, throttle cable binding) or an unmetered vacuum leak...and a large one at that. Ignore the 6pi and vdi right now, even of those are stuck it wont cause the problem you currently have.
Old Feb 28, 2012 | 03:04 PM
boosted414's Avatar
547hp at the flywheel
its definitely a vac leak combined with the TPS being most likely bad or out of adjustment
Old Feb 28, 2012 | 04:51 PM
87FCna's Avatar
Stoned
where's the "tps" located?
Old Feb 28, 2012 | 05:55 PM
boosted414's Avatar
its the 2 black plungers on the side of the throttle body connected to that plug you are disconnected.
http://atkinsrotary.com/store/images...91T-TPS-01.jpg
Old Feb 28, 2012 | 08:13 PM
87FCna's Avatar
Stoned
i tryed the curb cleaner with ever hose & seal i saw. nothing happend,still did the bounceing. coolant looks soo nasty & smells bad. gotta change it. the tps is bad, i believe because when i push down on the throttle, the rpms drop alot. but still bounce. im taking it to dave at speed1 for a rebuild/streetport anyways.
Old Feb 28, 2012 | 11:27 PM
esjoson1126's Avatar
TyrannosaurusRX7
check UIM, LIM for vacuum leak, check TPS, check BAC, extra ground etc. good luck!
Old Mar 1, 2012 | 08:29 PM
87FCna's Avatar
Stoned
when i do replace my tps. how do i reset my idle?
Old Mar 5, 2012 | 07:44 AM
rotoman2's Avatar
bad aws
My 91 NA did exactly the same thing all of a sudden. The accelerated warm up valve (aws on the driver's side of the UIM) was Stuck open or something. I just plugged up the hose and everything was fine.
Old Mar 7, 2012 | 02:19 PM
SystemIDx's Avatar
My **** keeps breaking.
Edit: Nevermind someone already posted my solution.
