Would my FC pass inspection in NJ?
Old Feb 25, 2012 | 04:30 PM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
NJ Would my FC pass inspection in NJ?
I'm about to get car insurance finally after 2 years of owning my FC and I don't know if it will pass inspection or not. I have a resonator, no catalytic converter, aftermarket exhaust (probably a 2.5" straight pipe im not sure) and I've recently changed the oil.
Old Feb 25, 2012 | 07:28 PM
TyFc3s's Avatar
JPR imports helper monkey
LOL no..
Old Feb 25, 2012 | 07:42 PM
barkz's Avatar
lol well as long as youve done that then yes you should be all set...
Old Feb 26, 2012 | 12:34 AM
Justen's Avatar
You have a better chance of being attacked by a polar bear and a regular bear in the same day.
Old Feb 26, 2012 | 08:56 AM
GuiltySoul's Avatar
Perfectly Broken
No u will not, if I failed with a stock cat, then ur cat-less exhaust should be a no brainer
Old Feb 26, 2012 | 11:42 AM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
Well would buying a high flow cat be the solution? And if it is, would it be a direct fit in place of my resonator or will I need to buy something in addition to the cat?
Old Feb 26, 2012 | 09:52 PM
TyFc3s's Avatar
I stand by my original "LOL no.."
Old Feb 29, 2012 | 09:17 PM
freq's Avatar
MA
You can pass with a hiflo cat. Make sure your air pump is setup and working correctly.
Coochas
44
Nov 5, 2019 11:08 PM
Sethix
Nov 3, 2017 11:48 PM
