Cosmo 13b-rew
Old Feb 24, 2012 | 01:13 PM
drift13b88's Avatar
!!!Rotary Power!!!
Cosmo 13b-rew
what is the bare minimum to pull off a cosmo 13b swap in an fc3s, making it manual of corse?
do i need stand alone to run a manual tranny because the car only came auto?
is there a mount kit avalible in the states?
what about intercooler wise does stock motor have one?
Old Feb 24, 2012 | 02:15 PM
RexRyder's Avatar
It's 13B-RE. First why?
Old Feb 24, 2012 | 02:53 PM
stevensimon's Avatar
banzai sells engine mounts. if you run an aftermarket flywheel, your manual trans will work with that engine. the stock engine has an ic but it(the piping at least) wont work on the fc. you will probably benefit from a standalone engine management setup. this has been done countless times before so pull up a chair and grab a cup of coffee and read
Old Feb 24, 2012 | 03:00 PM
drift13b88's Avatar
!!!Rotary Power!!!
so stock ecu is out of the question? cant just slap a fd tranny clutch and flywheel? does the ecu need the auto tranny to function?
Old Feb 24, 2012 | 03:02 PM
drift13b88's Avatar
!!!Rotary Power!!!
plus ive seen a few people do it on here but im having troble finding the build threads could anyone point me in the right direction?
Old Feb 24, 2012 | 03:06 PM
Banzai-Racing's Avatar
Rotary Specialists
Here is our conversion http://www.banzai-racing.com/br_projects_vert_pg5.htm
Old Feb 24, 2012 | 03:11 PM
RexRyder's Avatar
Swap is not worth it unless you have some special reason, that's why I asked why???
Old Feb 24, 2012 | 03:14 PM
drift13b88's Avatar
!!!Rotary Power!!!
my biggest question and most needed answered is if the stock cosmo 13bre ecu is compatible with a fd3s tranny clutch and flywheel, as is when i drop the motor in if i can hold off on stand alone, cause funds will be tight? will upgrade to standalone later.
Old Feb 24, 2012 | 03:15 PM
drift13b88's Avatar
!!!Rotary Power!!!
my special reason? im special.
Old Feb 24, 2012 | 03:19 PM
RexRyder's Avatar
Me too!!! Well that's what I thought when I did it. Trust me not worth all the extra headaches and extra $$$ you need for it.
Anyway can't really answer your ecu question. However I'm sure you can run it off a t2 ecu. You would need to remove a lot of the misc unneeded ****. A little rewriting to the CAS and injectors, and other stuff I forgot.
Old Feb 24, 2012 | 03:20 PM
drift13b88's Avatar
!!!Rotary Power!!!
and my special car.
RexRyder's Avatar
*re-wiring!!!! Not rewriting.
stupid auto correct.
Old Feb 24, 2012 | 03:22 PM
RexRyder's Avatar
Dude really I have flared fenders and fc2k too. I guess we're both special????
Old Feb 24, 2012 | 03:24 PM
drift13b88's Avatar
!!!Rotary Power!!!
just basiclly shooting for one wildass widebody rx7 this side of the pacific ocean.
Old Feb 24, 2012 | 03:30 PM
you cant use an fd trans.. it wont bolt to the fc shell. nothing wrong with a decent t2 trans. and im sure you could use the fc computer if you move everything over to the re block but might as well take your time and do it right. even an e6k will handle it and they go almost daily for under 500$ with sensors and harness
Old Feb 24, 2012 | 04:04 PM
tuscanidream's Avatar
T2 Duo!
Eunos Cosmo had 13bre and 20brew. Fd3s had 13brew.
Old Feb 24, 2012 | 04:18 PM
RexRyder's Avatar
Uh, pretty sure it's 20B-RE.
Old Feb 24, 2012 | 05:08 PM
20b is re as well..
Old Feb 24, 2012 | 05:26 PM
Jaiyurai's Avatar
Endure Persevere Succeed
You can run the 13BRE on the S5 TII ECU. Its not the best but it will get it running. I wouldn't continue using the TII ECU in a performance application for the 13BRE. Tight on funds? Then you shouldn't be doing this swap.
Even on the cheap side, you're looking around $3000-4000 for a good running 13BRE swap. To do it the right way, you'll have to tear apart the motor, port it, and at least replace the exhaust sleeves to make good top end power. In stock form, the 13BRE makes decent low end and midrange, but lacks in the upper RPMs.
Stick with the TII 13BT. Save yourself the headache.
Here was my 13BRE swap using a Motec M4 ECU.
Old Feb 24, 2012 | 07:20 PM
drift13b88's Avatar
!!!Rotary Power!!!
all well said,
im not jumping into this but lets be real the money isnt the issue,
a little hard work and that doesnt start to sound like alot of money,
im on my thrid fc3s, there like a funds graveyard, but let it be said now,
this is the direction im going, ive learned alot and am looking into alot said,
in the end, any help is great, this is my second account ive been on here for years,
but thats why im here advice, thanks.
Old Feb 24, 2012 | 07:24 PM
drift13b88's Avatar
!!!Rotary Power!!!
+1 to everyones pics
wish i could change that thread label to 13b-re lol
Old Feb 24, 2012 | 10:06 PM
gear_grinder's Avatar
Don't hate my V8
you should be able to make the 13b-re run on any factory engine/wiring setup with enough wiring work and basic theory on automotive electrical systems. the real question is how well? a turbo setup should be able to run it okay, N/A ecu will probably have a rage if you let it see boost and the timing/fuel tables will be garbage.
Standalone is the best option but the most expensive assuming you already have the factory setup.
middle of the road option might be doing a "turbo swap" on the engine management (s4 IE 318 boost sensor, AFM, ecu etc...) and then rtek 2.1 or a combination of 1.8 and a piggy back (AEM FIC, apexi AFC, etc...) but by this time you'd probably almost have as much into it as a megasquirt or older haltech IMO
Old Feb 24, 2012 | 10:10 PM
drift13b88's Avatar
!!!Rotary Power!!!
so cosmo 13b-re ecu is deff out of the question being that it only came in a automatic car right, no one has comfermed that yet or not?
Old Feb 24, 2012 | 10:11 PM
drift13b88's Avatar
!!!Rotary Power!!!
will aftermarket ecu work with stock wirring harness?
yeah right
Old Feb 24, 2012 | 10:17 PM
drift13b88's Avatar
!!!Rotary Power!!!
you know with a turbo 2 tranny and all.
