will not idle when warm...
Old Feb 19, 2012 | 09:09 PM
RX-7GTU's Avatar
Big, Smokey Burnout
1986 N/A fc with 86k miles. has new exhaust, and will not idle when warm. i do not know if it did before the exhaust was put on, because i just bought the car. i would like to get this running right to be my daily driver, please help
Old Feb 19, 2012 | 09:47 PM
RotaryRocket88's Avatar
Top Down, Boost Up
TPS could be out of adjustment/bad, you may have significant vacuum leaks, or the idle adjust screw (top of TB), variable resistor or throttle stop may have been tampered with.
Old Feb 20, 2012 | 12:40 AM
Mouse2k4's Avatar
I had a problem recently where my 7 wouldnt stay running I had to feather the throttle when in neutral to keep the car from stalling out. Turned out I had a disconnected tube connected to the intake manifold. all I did was put it right back on and it worked just fine.
Old Mar 11, 2012 | 01:26 PM
RX-7GTU's Avatar
Big, Smokey Burnout
haven't figured the problem out yet, i adjusted the idle screw and it didn't fix it, there are no vacume lines disconnected, but i looked at the exhaust, and found the Y-pipe is like 1 and1/5 inch! no way is that big enough, could that be the problem?
Old Mar 11, 2012 | 02:12 PM
RotaryEvolution's Avatar
Sharp Claws
no
Old Mar 12, 2012 | 02:28 PM
Adverse's Avatar
I have a similar problem.
When my car is warmed up and i start it up "again" it wont start it cracks and stuff for a long time but nothing happens. It cant idle enough i guess?
but when i gas it a few times it starts as i crank the key.
Old Mar 14, 2012 | 10:50 PM
esjoson1126's Avatar
TyrannosaurusRX7
If you have followed and checked what RotaryRocket 88 have listed please add these to his chores. Ground and check your BAC. I hope it helps. Worked for me.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
