Haltech Hot start issue... fixed with BAC, but then everything goes nuts (E6k)
Old Feb 19, 2012 | 03:21 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
Angry Hot start issue... fixed with BAC, but then everything goes nuts (E6k)
Don't know what to do here... This is not a priming/fueling issue!
Like many FC's, I have a slightly annoying hot start issue. When the car is warmed up, it starts kicking and almost wants to start. I can save it by ever so slightly touching the gas. Then it's fine and idles fine. I fixed this using my BAC valve by cranking up the "hot opening position" past 90%. The engine started immediately and I didn't have to touch the gas. Then it all went to ****!
The idle would surge and go bonkers I'd have to run and unplug the BAC. If I lower the hot opening position to under 85% or so, it no longer opens and is no longer useful.
I always thought the "hot opening position" was there for cranking, based on the old hitman guide?
I think my haltech is possessed. TPS is calibrated if that matters. I plugged in a spare BAC valve and kept it right in front of me when playing with the laptop. I noticed some very odd behavior. If I rev the engine, the valve opens. Why? I dropped the target idle speed to 600 to specifically not allow the BAC to kick on because my idle is over 900RPM. IT'S STILL OPENING. Why the hell is it trying to raise my idle when my idle is 300RPM higher than the target? I got frustrated and set every position to 0% and... the valve still opens when I press the gas. Now I'm really confused. I even tried other PWM outputs. I seemed to have created some sort of drive by wire using a BAC valve. Maybe I should disconnect my throttle cable.
I think I'm going to switch the PWM output from BAC to Stall Saver and see if that helps with hot starts.
Old Feb 20, 2012 | 09:51 AM
beefhole's Avatar
**** it! I bought this thing. I'll do it RIGHT with a proper stepper motor. No use in bothering with the primitive BAC anymore.
Old Feb 20, 2012 | 10:11 AM
20B10AE's Avatar
Gone Darkside
Nice adapter! Good luck with the new setup!
Old Feb 20, 2012 | 12:55 PM
Fero313's Avatar
Infinite Rotary Resolve
I really want to try one of those..... Sadly I have a Sprint RE. All the awesome ECUness without the features of a 10+ yr old EMS.
Old Feb 20, 2012 | 06:47 PM
beefhole's Avatar
Well, it still has much better (modern) software and better features (overboost!). Although the limited TWO outputs is pathetic with all those options... If it had at least 4, I would be willing to give up idle control and have a modern computer.
Old Mar 9, 2012 | 08:27 AM
SirCygnus's Avatar
whats going on?
where can i get the stepper motor for that piece?
Old Mar 9, 2012 | 09:11 AM
C. Ludwig's Avatar
www.lms-efi.com
Autozone, etc.
Tell them you have an 89 Trans Am turbo. See if they even flinch. The connector is a square 4-pin Weatherpack. The pinout is on the Haltech ECU schematic.
Old Mar 9, 2012 | 09:33 AM
SirCygnus's Avatar
whats going on?
for the stepper motor that fits in the rising rpm piece?
Old Mar 9, 2012 | 09:46 AM
Fero313's Avatar
yes
Old Mar 9, 2012 | 11:22 AM
C. Ludwig's Avatar
www.lms-efi.com
Correct. It was used on a ton of GM crap in the 80s. I like telling the parts guy to get me parts for obscure stuff to see if they even flinch when you offer up a low volume model. If they do happen to ask if you have one, you completely blow their mind when you say, "No. It's going on a Mazda RX-7."
The 89 TAt also uses the GM 3 bar MAP sensor and the 3/8" NPT coolant and air temp sensors.
Old Mar 9, 2012 | 11:46 AM
beefhole's Avatar
I bought my valve on summitracing for 34 dollars or so. They are still somewhat pricey I suppose...
The E6k pinout (wiring diagram) just had 4 inline wires labeled Idle1 thru 4, A thru D. It is NO HELP.
The idle valve is SQUARE. It's up to you to figure out which wire goes to what on the GM valve. I searched around online and was able to figure it out. It is NOT pin A from the haltech to Pin A on the valve, B to B et cetera. I can tell you all later what it is when I get home.
Check my other recent thread... I got it all working, it's GREAT.
Old Mar 21, 2012 | 06:58 PM
AlexG13B's Avatar
brap brap brap
Wat are the pin for the wires?
Old Mar 23, 2012 | 12:02 PM
beefhole's Avatar
Derp... I have to go find out and write it down. Perhaps tonight.
Old Mar 24, 2012 | 03:01 PM
beefhole's Avatar
OK here is my FIERCE mspaint schematic. Fierce I tell you!
Old May 12, 2013 | 09:40 PM
SirCygnus's Avatar
whats going on?
Could you elaborate on the wiring colors?
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
tsmith94FD
Aug 16, 2015 05:41 PM
befarrer
Aug 14, 2015 04:18 PM
