Ignition and keyhole light won't turn off
Old Feb 18, 2012 | 02:16 AM
TrueUp's Avatar
So the keyhole illumination and ignition light stay on all the time on my S5. I think its draining my battery as I had to change it recently. I tried resolder the joints on the CPU but it didn't seem to do anything (although my solder skills are probably not very good) but I don't think this is the problem since the wiring diagram shows that the seatbelt buzzer is also controlled by the same plug and I haven't had a problem with the buzzer.
I took the door handle out and everything looks okay. It looks like there's a switch that's activated by the door handle which I'm assuming controls these lights and it doesn't seem to be stuck but I'm not exactly sure what I should be looking for.
Does anyone have any suggestions?
I'm mostly concerned with the battery drain so if I can't fix the problem and I cut the wires to either the switch or the light bulb would this eliminate the battery drain?
Thanks
Old Oct 25, 2016 | 01:21 PM
mquinn's Avatar
Newbie
me too...
No takers on a suggestion to this old post? I just realized this when I went by my car last night with the charger on - could not figure out why my battery is always draining...
M.
Old Oct 25, 2016 | 03:47 PM
misterstyx69's Avatar
Retired Moderator, RIP
Do an amperage draw test on the car...undo the steering column surround,take the bulb out and do an amperage draw test again.
If the bulb is drawing current then that circuit is being activated somehow.The easy fix is to remove the bulb.
Old Dec 26, 2016 | 07:38 AM
b3delta's Avatar
FD Wiring Guru
Tenured Member: 5 Years
Interesting, this happens to my 94 PEP as well
Old Dec 27, 2016 | 04:01 PM
OG BBF's Avatar
M.
sounds like a parasitic drain. As mentioned above do a draw test on your battery with the key out, plenty of guides online on how to do it....just remember to ensure that if you have to have the doors open for whatever reason tape the door open switch down so the interior light doesn't come on. You don't want anything to be on or activated aas this will give you a drain reading but it actually be a legitimate one.
If you do the test and are drawing anything above 40-50Ma go to the fuse box and starting from the top pull one fuse out and retest the battery.....keep doing this till you remove a fuse and that current draw on the battery disappears. Now you have found which circuit is causing the drain.
Get the FSM wiring manua out (plenty online) and find out what's on that circuit then you'll have to test everything see which of these is draining current. Usually if everything on the same circuit is drawing it'll be a short or break that is affecting that section of the wiring harness.
Old Dec 28, 2016 | 12:35 PM
satch's Avatar
Take a reading from the Yellow wire in the largest CPU plug and tell us what you get. This wire is from the door handle switch which sends a signal to the CPU to so as to tell whether the illumination lights you speak of turn on or not.
Old Dec 29, 2016 | 11:42 AM
mquinn's Avatar
Newbie
what reading
Is this a voltage reading or ohm reading that you are looking for on the yellow wire?
need this with door open - or after door has been closed for a certain amount of time?
Thanks!
M.
Old Dec 29, 2016 | 12:15 PM
satch's Avatar
Thanks!
M.
It would be a voltage reading and you could take the reading under differing circumstances. Immediately after opening the door, minutes after the door was open.
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
