Air Conditioning
Old Feb 14, 2012 | 03:06 PM
jtalar's Avatar
NV Air Conditioning
Who makes the conversion kit for the Air conditioning from R12 ro 134?
Old Feb 14, 2012 | 11:53 PM
DreamInRotary's Avatar
Always Wanting to Learn
Check this out CONVERSION KIT, should help. I am looking into doing the same thing for the upcoming summer
Old Feb 15, 2012 | 03:39 PM
13x's Avatar
13x
Sin City Rotary
virtually any parts store should have, considering that they are o-rings it's easy enough. I have an a/c o-ring assortment. But considering how small the system is I charged mine with R-12 I make do with 40-45 degree vent temps lol. Would also suggest replacing the reciever drier as well
Old Feb 15, 2012 | 06:39 PM
Sgt Fox's Avatar
Stigulus Moderatorai
Look into R-152 in the FC section. Its cheaper and better suited to the old system.
Old Feb 15, 2012 | 09:45 PM
JohnCarter's Avatar
I'm just getting started, and I'm looking for a way to drain my AC - is there any noob-friendly way to do it that doesn't involve taking it to a shop?
Old Feb 15, 2012 | 11:33 PM
jtalar's Avatar
13x, I didn't think any shops still used R12.
Old Feb 16, 2012 | 12:25 AM
13x's Avatar
13x
Sin City Rotary
You'd want to evacuate the system, Harbor Freight has something you use with your air compressor not the fastest but is cheap and works other companies carry the same exact tool at 3 to 4 times the cost. But of course this is if your system is empty as you would not want to open the system to the enviroment
errrr dude due to the cost they are kept under my desk lol but yes they are available. You know if mama is happy you might be as well, if she's not your not
Old Feb 16, 2012 | 09:50 PM
jccNV's Avatar
The most important is the oil you have to drain the oil of the a/c compressor, flush the entire a/c system. also replace the a/c drier (acumulator ). the fitting really i dont care as long that you remenber what type of freon you are using.
the oil on the r 12 is mineral and r 134 is pag. they are not compatible.
Old Feb 17, 2012 | 09:12 AM
Sgt Fox's Avatar
Don't use PAG on a conversion. You want to use Ester oil.
I also suggest you read this thread: https://www.rx7club.com/showthread.p...ghlight=r-152a
It works amazingly well.
Queppa
Nov 18, 2024 03:47 AM
Brice_Brice
Aug 18, 2015 10:42 AM
